John2189 497 #1 Posted September 13, 2022 any body know what this is? It’s steel don’t know anything else about it 1 1 Share this post Link to post Share on other sites
John2189 497 #2 Posted September 13, 2022 another pic 1 Share this post Link to post Share on other sites
SylvanLakeWH 27,230 #3 Posted September 13, 2022 Husband “Teacher”? Looks like our wives could use it to persuade us of the error of our ways with a few knocks on our noggins… 1 1 3 Share this post Link to post Share on other sites
ebinmaine 70,384 #4 Posted September 13, 2022 I got nothin' but I'm looking forward to hearing what it is 1 Share this post Link to post Share on other sites
ri702bill 8,922 #6 Posted September 13, 2022 Wild guess - animal hoof cleaner / scraper ?? 1 Share this post Link to post Share on other sites
Pullstart 64,387 #7 Posted September 13, 2022 Pineapple corer/juicer? 1 Share this post Link to post Share on other sites
Pullstart 64,387 #8 Posted September 13, 2022 Drainbob? 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #9 Posted September 13, 2022 Some sort of a 'pestle' ? 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #10 Posted September 13, 2022 @formariz what do you think this is 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #11 Posted September 13, 2022 I think you might be right jeff 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #12 Posted September 13, 2022 Some sorta 'star drill' ? Does it appear to ever have been 'struck' on the knob end? 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #13 Posted September 13, 2022 2 hours ago, John2189 said: It’s steel Not cast iron? 1 Share this post Link to post Share on other sites
John2189 497 #14 Posted September 13, 2022 8 minutes ago, Jeff-C175 said: Not cast iron? Don’t know I don’t have it Share this post Link to post Share on other sites
John2189 497 #15 Posted September 13, 2022 19 minutes ago, Jeff-C175 said: Some sort of a 'pestle' ? That is my guess. Some sort of crusher. But I don’t know. Share this post Link to post Share on other sites
formariz 11,993 #16 Posted September 13, 2022 I am a bit confused by third photo. Is it same item? it certainly looks like an old garden dibber used to dig a shallow hole to plant something like a bulb or a bare root plant. They are usually pointed. On that one a slight twist once inserted will loosen soil rather than just piercing a cone shaped hole as usual. 4 Share this post Link to post Share on other sites
John2189 497 #17 Posted September 13, 2022 4 minutes ago, formariz said: I am a bit confused by third photo. Is it same item? it certainly looks like an old garden dibber used to dig a shallow hole to plant something like a bulb or a bare root plant. They are usually pointed. On that one a slight twist once inserted will loosen soil rather than just piercing a cone shaped hole as usual. Yes same item 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #18 Posted September 13, 2022 4 minutes ago, formariz said: a bit confused by third photo I was too until I realized it was a bottom view showing the three radial 'arms'. That's what made me think 'star drill'. 2 Share this post Link to post Share on other sites
formariz 11,993 #19 Posted September 13, 2022 1 minute ago, Jeff-C175 said: I was too until I realized it was a bottom view showing the three radial 'arms'. That's what made me think 'star drill'. I see now. It is definitely designed to pierce through a loose or soft substance such as dirt, sand or grain. It allows easy penetration and the gullets allow material to move upwards away from tip. 1 Share this post Link to post Share on other sites
Handy Don 13,260 #20 Posted September 13, 2022 (edited) Still, clearly intended to be wielded by hand with one's arm position mostly horizontal--like a Native American corn pestle. The "pointiness" of the business end leads me to think more of something breaking and grinding something with shells like small nuts--maybe acorns? Edited September 13, 2022 by Handy Don 1 Share this post Link to post Share on other sites
formariz 11,993 #21 Posted September 13, 2022 (edited) 5 minutes ago, Handy Don said: The "pointiness" of the business end leads me to think more of something breaking and grinding something with shells like small nuts--maybe acorns? Wouldn’t that shape defeat it for that purpose? It would push it away rather that keep it underneath for crushing. The gullets all the way to top look very intentional. Edited September 13, 2022 by formariz 1 Share this post Link to post Share on other sites
Handy Don 13,260 #22 Posted September 13, 2022 Just now, formariz said: Wouldn’t that shape defeat it for that purpose? It would push it away rather that keep it underneath for crushing. Yes, it'd be only to get the shells cracked. Then remove the shells and resume with a more conventional round-end pestle. BUT I could still be totally "out to lunch" on this! Putting it into soil of sand seems unlikely to. me since it'd have too much friction going in and the stuff would stick when the tool was retracted collapsing the sides of the hole (unless the consistency was perfect). 1 Share this post Link to post Share on other sites
lynnmor 7,545 #23 Posted September 13, 2022 21 minutes ago, formariz said: it certainly looks like an old garden dibber used to dig a shallow hole to plant something like a bulb or a bare root plant. They are usually pointed. On that one a slight twist once inserted will loosen soil rather than just piercing a cone shaped hole as usual. That was my thought as well, also I thought it might be used to make or clean out holes in wet concrete. 3 Share this post Link to post Share on other sites
8ntruck 7,333 #24 Posted September 13, 2022 This would be a good test case for the new 'search by what it looks like' feature of a major search engine. 1 Share this post Link to post Share on other sites
Handy Don 13,260 #25 Posted September 13, 2022 40 minutes ago, 8ntruck said: This would be a good test case for the new 'search by what it looks like' feature of a major search engine. It was, and it didn't yield anything useful. 1 Share this post Link to post Share on other sites
