ri702bill
Function of this Steering Part -502, 552, 702
ri702bill
First off, thanks to  @DouglasParker for the good picture. The sheet metal tab on the end of the right steering arm and tiebar pivot is not even shown or listed in the 502, 552, and 702 Manual. Only one piece, none on the left side. My two 702's and the 502 all have one - what does it do??? Limit spindle rotation??
Edited by ri702bill
Achto
Chiming in, cause I have never seen that part before.
953 nut
The metal part that saddles over the steering arm keeps the nut from coming loose. The shoulder bolt passes through the tie rod and steering arm and the saddle acts as a washer.
  • Thanks 3
Pullstart
I too have wondered that question and have even mentioned it before.  @953 nut should they be on both sides then?
953 nut
I would think so, but you know how things can come up missing in the heat of the moment.
Racinbob
It isn't on any parts list.
:confusion-shrug:
953 nut
:confusion-shrug:
I know,   :confusion-confused:    the 400 Suburban I owned had them on both ends of the tie rod yet others of the same year didn't even have a grease fitting in the pin. The RJ didn't have anything retaining the pin except a cotter key on the right and a round steering arm passing through it on the left side.   @Wild Bill in VA, come on over and school us on this dilemma please.
gwest_ca
Have seen steering stops mentioned but don't know what they are. Maybe this is it.
Item #1 in this service bulletin
ri702bill
Well, that explains why it is not on the drawing or the parts list...Thanks Garry.
Edited by ri702bill
Wild Bill in VA
Ok Ok that little metal tab was to keep the steering arm from breaking. In the beginning those cast steering arms would break easy, so Wheel Horse added the more malleable steel to give a little when the steering was pulled hard in a tight turn and the arm contacted the #4220 type axle.
Wild Bill in Richmond VA.
  • Excellent 2
Mike in NC
I just looked at our 702 and it has that on the right side but not the left also.
