Gregor 4,847 #1 Posted September 6, 2022 School me on plasma cutters. Do they require a LOT of air for an extended period, like a sand blaster, or not that much? Thanks Greg Share this post Link to post Share on other sites
ebinmaine 70,364 #2 Posted September 6, 2022 This here Bear 🐻 will be following along... Share this post Link to post Share on other sites
squonk 42,339 #3 Posted September 6, 2022 (edited) Look on line at a particular model you're interested in and see the SCFM specs of it. To be precise, the air pressure required for a plasma cutter is about 4-8 SCFM at 90-120 PSI. This plasma cutter air pressure is a generalization for cutting steel between 3/8" and 7/8" thick Edited September 6, 2022 by squonk Share this post Link to post Share on other sites
Gregor 4,847 #4 Posted September 6, 2022 is about 4-8 SCFM at 90-120 PSI So are we talking 1/2hp compressor, 10 gallon tank? 2 hp compressor, 15 gallon tank? 5 hp compressor, 60 gallon tank? Those numbers mean nothing to me. Share this post Link to post Share on other sites
Bill D 2,080 #5 Posted September 6, 2022 How thick is the metal you plan to cut? Some machines have built in air compressors. My experience with air compressors and plasma cutters is the bigger the better. 3 Share this post Link to post Share on other sites
Heatingman 971 #6 Posted September 6, 2022 60 gallon tank or better for continuous or near continuous use. But as pointed out above, you gotta look at specs. For reference my 60 gallon tank is rated to 11.5 cfm at 90 psi Share this post Link to post Share on other sites
Heatingman 971 #7 Posted September 6, 2022 54 minutes ago, Gregor said: is about 4-8 SCFM at 90-120 PSI So are we talking 1/2hp compressor, 10 gallon tank? 2 hp compressor, 15 gallon tank? 5 hp compressor, 60 gallon tank? Those numbers mean nothing to me. The ratings are generally written in plain easy to find english often a little chart on the tank. Share this post Link to post Share on other sites
Ed Kennell 40,285 #8 Posted September 6, 2022 Rule of thumb for small compressors. 1HP for each 4SCFM 1 Share this post Link to post Share on other sites
Bill D 2,080 #9 Posted September 7, 2022 You will also want extremely dry air for a plasma cutter. Several post compressor water traps and filters will be needed. If you go with a big compressor, consider adding an air cooler and water separator in the line going from the pump to the tank. Several videos on YouTube that show how people have done this. Like with most things on YouTube, use your judgement and proceed at your own risk. 1 Share this post Link to post Share on other sites
Bill D 2,080 #10 Posted September 7, 2022 You will also want extremely dry air for a plasma cutter. Several post compressor water traps and filters will be needed. If you go with a big compressor, consider adding an air cooler and water separator in the line going from the pump to the tank. Several videos on YouTube that show how people have done this. Like with most things on YouTube, use your judgement and proceed at your own risk. I had a plasma cutter, but I sold it to a friend. I didn't use it enough. Hypertherm makes some of the best machines on the market, but they're pricey. Share this post Link to post Share on other sites
sjoemie himself 3,072 #11 Posted September 7, 2022 First: you have to decide how thick the material is you would want to cut. Second: based on that you look for the plasma machine you want to buy. That dictates the cfm needed. Third: based on that you decide what kind of compressor you need. This is IMHO the only way to do it right, or atleast that's how I purchased my plasma machine and compressor. 1 Share this post Link to post Share on other sites
