DeepH2O
Correct Pulley Part Numbers
DeepH2O
Could someone point me in right direction as far as correct replacement pulley part numbers for a 42” side discharge model 1542SC01. I’m seeing 2 part numbers on every drawing I find. I’m guessing 1 number is for 48” and other for 42”. I’m wondering if someone, out of first hand knowledge, has ordered these with success. I have the idler pulley. I need double pulley which looks to be 110148 and the 2 side pulleys which would both be same part numbers. Guessing, I would think since the 42” double pulley is the bottom part number, the part number for the side pulleys is 109967? Any reassurance is appreciated.
76c12091520h
Blade set #106636
Spindle belt #6738
PTO belt #94-2501
Outer pulley #109967
Idler pulley #112425
Center pulley #110148
  • Excellent 3
Handy Don
On 9/3/2022 at 7:03 AM, 76c12091520h said:
Blade set #106636
Spindle belt #6738
PTO belt #94-2501
Thanks for posting this. I'm commenting to add the name and model so this will be found more easily by searching!
