DeepH2O 66 #1 Posted September 3, 2022 Could someone point me in right direction as far as correct replacement pulley part numbers for a 42” side discharge model 1542SC01. I’m seeing 2 part numbers on every drawing I find. I’m guessing 1 number is for 48” and other for 42”. I’m wondering if someone, out of first hand knowledge, has ordered these with success. I have the idler pulley. I need double pulley which looks to be 110148 and the 2 side pulleys which would both be same part numbers. Guessing, I would think since the 42” double pulley is the bottom part number, the part number for the side pulleys is 109967? Any reassurance is appreciated. Share this post Link to post Share on other sites
76c12091520h 3,692 #2 Posted September 3, 2022 Blade set #106636 Spindle belt #6738 PTO belt #94-2501 Outer pulley #109967 Idler pulley #112425 Center pulley #110148 3 Share this post Link to post Share on other sites
Handy Don 12,840 #3 Posted September 4, 2022 On 9/3/2022 at 7:03 AM, 76c12091520h said: Blade set #106636 Spindle belt #6738 PTO belt #94-2501 Outer pulley #109967 Idler pulley #112425 Center pulley #110148 Thanks for posting this. I'm commenting to add the name and model so this will be found more easily by searching! 42” side discharge model 1542SC01 Share this post Link to post Share on other sites
