TJ5208
C-160 8
TJ5208
Hey guys i thought i would introduce my latest member of the herd a C-160 8 It needs a new fuel pump its cracked and definely a seat. I think it will clean up nicely.
  • Like 5
  • Excellent 2
EB-80/8inPA
Congratulations!
TJ5208
1 minute ago, EB-80/8inPA said:
Congratulations!
Thank you he comes home soon I got it for 400.
kpinnc
:ranting:
One day, I will get one.
Congrats! :thumbs:
Edited by kpinnc
Retired Wrencher
4 hours ago, kpinnc said:
:ranting:
Congrats! :thumbs:
I am with you on that. Still looking. TJ That will make a good worker for you Enjoy it. Don't see many 8 speeds. Lots of auto`s.
Edited by Retired Wrencher
953 nut
9 hours ago, TJ Salyers said:
definely a seat
Once they start turning green and stuff is growing on them it is time,     good buy.            :text-coolphotos:
EB-80/8inPA
A little green?  Buffs right out!
  • Haha 2
Achto
Congratulations !! That will be a great tractor after a little TLC. :handgestures-thumbupright:
  • Thanks 1
peter lena
@TJ Salyers nice pick up , opportunity , to give that an aerosol penetrating oil soak down , let it sit a day , wipe down till dry , do it again . you have just saved patina !  easy to maintain . when you replace that fuel pump , you could also  add a vertical fuel check valve , from fuel pump to carb , after you drop the carb bowl for cleaning , https://www.amazon.com/Wolfride-Return-Check-Petrol-  have these on my 3 kohler magnums , always holding a fuel charge right there , also used clear fuel rated hose , dark green  squeeze clamps , exact size . lots of hours and instant starts , why not ,?   seat / type is easy on line , or local farm store . personally add  rislone zinc additive to my rotella 30 oil changes , engines sound and run , very strong , do a very thorough baseline , drain / and electrical check over , use super lube oil on those choke / throttle cables , just  some ideas , on what I  do regularly to my stuff , good luck . pete    evel energy fuel check valves , on line 5/16
  • Excellent 1
peter lena
@Snoopy11 , tell it like I  see it , opportunity  is regularly staring at me on another's problem , not only fix / repair it , but while you are there  step it up a notch ?  the commonality  build of these horses , lets you quickly say what you did on a  similar problem . just got thru cutting with my c-85 , magnum , my franken horse test bed , that  horse works / runs  so effortlessly its ridiculous , very smooth , at every  function . just a lot of tweaking time  ,  keep experimenting , pete
  • Excellent 1
Snoopy11
I need to make a trip to Connecticut... we can share notes... :P
Don
Sailman
Congrats on the find. I have both a C-160 Auto and 416 - 8. My favorite tractors. They will do anything you want them to.
Enjoy!
Sparky
Nice!
  Much better purchase than a second 520 in my opinion.
  A mid 70’s C series with a Kohler single is the perfect machine to learn some mechanical & restoration skills…and in the end you will have a desirable tractor
  • Like 8
EB-80/8inPA
23 minutes ago, Sparky said:
Nice!
And a lot cheaper, too!
  • Like 4
TJ5208
It does run the guy took some tape and put it on the fuel pump and it fired right up. I think i did good buying this tractor. Im definely going to put a stack on it.
Edited by TJ Salyers
peter lena
@Sparky agree with you on the  mid 70,s  C series , personally think its the opportunity , to cross breed the old school  ruggedness with some  upgrades , that you probably won't even see . basically detailing / improving function , and retaining the look . bought a 3/14  a few years ago , for parts , guy I  got it from was blown away  at the combinations , that I  set up on my horses , could not believe that attachments could operate that easily . take advantage of  strength , design , tweak it , it just  works , so much better . just the way I  see things , oil slick , pete
TJ5208
Heres some more pics.
Retired Wrencher
On 9/2/2022 at 2:19 AM, kpinnc said:
:ranting:
Congrats! :thumbs:
You and me both!
