Evguy 556 #1 Posted August 31, 2022 The saga, I just wanted an ignition switch to replace missing switch on my 314. I bought a switch on eBay, the switch they said fit, was incorrect. I ordered the correct switch from another vendor, looking correct, I installed it. I kept blowing a fuse, I had done a lot of wiring changes with engine swap. After checking all my work, I found the new switch grounding battery and acc as it was turned on, in run it was fine, between off and run It shorted battery to ground. Cheap parts are cheap for a reason. 2 3 Share this post Link to post Share on other sites
ebinmaine 69,710 #2 Posted August 31, 2022 7 minutes ago, Evguy said: Cheap parts are cheap for a reason. A valid warning that should be well heeded. I've had EXACTLY the same issue. I now stick to known name brands for ignition switches and have advised others to do so as you are today. For a Wheelhorse tractor I try VERY hard to use OEM switches ONLY. 103990 or 103991. For $20 or $25 shipped to my door... Why use anything else? 8 Share this post Link to post Share on other sites
Evguy 556 #3 Posted August 31, 2022 14 minutes ago, ebinmaine said: A valid warning that should be well heeded. I've had EXACTLY the same issue. I now stick to known name brands for ignition switches and have advised others to do so as you are today. For a Wheelhorse tractor I try VERY hard to use OEM switches ONLY. 103990 or 103991. For $20 or $25 shipped to my door... Why use anything else? Where do you get the oem for that price? 1 Share this post Link to post Share on other sites
Pullstart 63,537 #4 Posted August 31, 2022 11 minutes ago, Evguy said: Where do you get the oem for that price? At his door 1 5 Share this post Link to post Share on other sites
ebinmaine 69,710 #5 Posted August 31, 2022 10 minutes ago, Evguy said: Where do you get the oem for that price? Various places off the interwebs. One must be cautious to avoid words like replaces or fits. 2 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,753 #6 Posted August 31, 2022 (edited) 8 hours ago, Pullstart said: At his door That’s a whole nuther level of wiseheimering. Thanks for the chuckle! Edited August 31, 2022 by EB-80/8inPA 2 1 Share this post Link to post Share on other sites
953 nut 56,743 #7 Posted August 31, 2022 11 hours ago, Pullstart said: At his door Made my ribs hart and mine ain't even broke. 1 2 Share this post Link to post Share on other sites
ebinmaine 69,710 #8 Posted August 31, 2022 2 minutes ago, 953 nut said: Made my ribs hart and mine ain't even broke. Ooooooooooooooo Share this post Link to post Share on other sites
rmaynard 15,801 #9 Posted August 31, 2022 11 hours ago, Evguy said: Where do you get the oem for that price? https://www.amazon.com/GENUINE-OEM-TORO-PARTS-ASSY-SWITCH/dp/B0195V4I8Y/ref=sr_1_4?keywords=toro+103990&qid=1661948478&sr=8-4 Just one example. 2 1 Share this post Link to post Share on other sites
Evguy 556 #10 Posted August 31, 2022 3 hours ago, rmaynard said: https://www.amazon.com/GENUINE-OEM-TORO-PARTS-ASSY-SWITCH/dp/B0195V4I8Y/ref=sr_1_4?keywords=toro+103990&qid=1661948478&sr=8-4 Just one example. Thanks, but for some reason the switch I need is 40-80 bucks. Not sure why. Same switch under Hustler brand is far less. Share this post Link to post Share on other sites
rmaynard 15,801 #11 Posted August 31, 2022 1 hour ago, Evguy said: Thanks, but for some reason the switch I need is 40-80 bucks. Not sure why. Same switch under Hustler brand is far less. What is the part number for the one you want? Share this post Link to post Share on other sites
Evguy 556 #12 Posted August 31, 2022 It’s showing 92-6785 Toro number, it a 314-8 1993, uses magneto. 5 pin switch Share this post Link to post Share on other sites
rmaynard 15,801 #13 Posted August 31, 2022 You are correct. On Amazon the Genuine Toro 92-6785 is $41.22 with free shipping. It's your choice, aftermarket for about $18 or Toro for $41. They are both probably made in China. 2 Share this post Link to post Share on other sites
Evguy 556 #14 Posted September 8, 2022 I ended up getting a stens brand, working properly now 4 Share this post Link to post Share on other sites
ebinmaine 69,710 #15 Posted September 8, 2022 2 minutes ago, Evguy said: I ended up getting a stens brand, working properly now Excellent. Glad to hear it's up n going. 2 Share this post Link to post Share on other sites
