Jiminoh
Seals
Jiminoh
I was wondering if l can change the seals on my uni drive without breaking the open.
Jiminoh
Trans.
Pullstart
Depending on the bearing condition, you should be able to pull the axle seals externally with a screw or punch, then replace them over the axle.  Tape off your axle keyway slot with electric tape and use some grease too!
ri702bill
Bearing condition - If the bearing is shot, the seal becomes the victim, not the problem. Up and down, or front to back noticable play in the axle to bearing is indicative it's time to yank the Unidrive, open it up and access the extent of the complete project requirements. (and damage to the wallet....)
