Jiminoh 27 #1 Posted August 29, 2022 I was wondering if l can change the seals on my uni drive without breaking the open. Share this post Link to post Share on other sites
Pullstart 68,521 #3 Posted August 29, 2022 Depending on the bearing condition, you should be able to pull the axle seals externally with a screw or punch, then replace them over the axle. Tape off your axle keyway slot with electric tape and use some grease too! 3 Share this post Link to post Share on other sites
ri702bill 10,570 #4 Posted August 29, 2022 Bearing condition - If the bearing is shot, the seal becomes the victim, not the problem. Up and down, or front to back noticable play in the axle to bearing is indicative it's time to yank the Unidrive, open it up and access the extent of the complete project requirements. (and damage to the wallet....) 2 Share this post Link to post Share on other sites
