Hampton
Tiller hitch brackets for 07-36TL04
Hampton
These are the ones on Wheel Horse Parts and More. Are these the ones I need? for the tiller?
ri702bill
Did you call Lowell and get his advise - they are great folks to do business with.
Hampton
Not yet. Thought I would check here first,
peter lena
@Hampton  that hitch is for a plow blade / frame set up  , don,t think  it has anything to do with tiller , look this up , pete
Hampton
This is what was on the sellers 312-8 for the tiller.
Hampton
The photo in the first post is listed under tiller parts. I'll give them a call tomorrow.
Edited by Hampton
Thor27
That is the bracket
Hampton
20 minutes ago, Thor27 said:
That is the bracket
It seems to be a dual purpose bracket for a tiller and snow plow. The middle bar is a spacer to attach it correctly. Again, I'll give them a call.
peter lena
@Hampton  sorry to give you incorrect info on the bracket, had only seen that bracket used on the plow set up , but that simple easy hook up for the tiller is right there , never seen one , BTW  do a thorough lubrication service on the tiller , before use , probably over due . pete
clueless
The picture of the hitch you posted is the right one for the tiller. That one actually has the top angle iron on the left for the assist spring to hook to, most new and old hitches don't come with that piece.
Edited by clueless
Hampton
I've called them to verify. Haven't heard back just yet. Later time zone rhan where I am. Lol
