pacer 3,175 #26 Posted August 27, 2022 Yeah, run the engine at around 1500/2000 rpm (fast idle?) Course if you use the multimeter at the battery and it shows 13-14 DC then that also will tell you the rectifier is good. If you have that, then ..... well you'll have to revert back to all the stuff the guys have been describing.... Dont have a multimeter? then for sure GET one, HF has a small one for around $10, you really cant do much with wiring without one. 2 Share this post Link to post Share on other sites
Kenneth R Cluley 582 #27 Posted August 27, 2022 When I run into a mess like that, I usually tear it all out and start from scratch with diagram as guide. Saves a lot of time and guessing. 2 Share this post Link to post Share on other sites
Jeff-C175 7,203 #28 Posted August 27, 2022 @RITEK I've seen worse wiring... at least yours aren't just twisted together and taped! But, what the heck is this? I hope that's not part of a 'fix' ? Share this post Link to post Share on other sites
RITEK 25 #29 Posted August 27, 2022 23 hours ago, lynnmor said: Download the Onan service manual and do the tests, but first be sure that the regulator is grounded with its mounting bolt and the engine is grounded well at the battery cable. So I haven't tested yet but I have an update I just installed the new starter and the voltage is now in the 16v red zone not the 11v Share this post Link to post Share on other sites
RITEK 25 #30 Posted August 27, 2022 Just hooked up the multimeter and the gage on the tractor says 12.7 or 12.6 and multimeter says 11.5 without the tractor running Share this post Link to post Share on other sites
Handy Don 13,340 #31 Posted August 27, 2022 Tractor voltage meters are not always useful for fine measurement. I'd be more inclined to trust a good voltmeter (assuming if it is analog that it has been correctly zeroed before use). Still, I'm not sure what you are trying to accomplish here if you aren't going to do sequential diagnostic tests. Share this post Link to post Share on other sites
RITEK 25 #32 Posted August 27, 2022 8 minutes ago, Handy Don said: Tractor voltage meters are not always useful for fine measurement. I'd be more inclined to trust a good voltmeter (assuming if it is analog that it has been correctly zeroed before use). Still, I'm not sure what you are trying to accomplish here if you aren't going to do sequential diagnostic tests. Well now the engine won't run and I have no spark and I realized this tractor has been re wired before and there are extra wires leading to numerous things Share this post Link to post Share on other sites
Handy Don 13,340 #33 Posted August 28, 2022 2 hours ago, RITEK said: Well now the engine won't run and I have no spark and I realized this tractor has been re wired before and there are extra wires leading to numerous things It can be frustrating but, as other above have mentioned, sometimes you gotta go backward (and remove unknown/untrusted wiring) before you can go forward successfully. Consider it a tactical move, not a retreat! Share this post Link to post Share on other sites
