Bill Claffey
WALBRO CARB LMK 43 1048 1205380
Bill Claffey
I HAVE A  WHEEL HORSE 314-8 TRACTOR  WITH A KOHLER COMMAND CH14S ENGINE EQUIPED WITH A WALBRO LMK 43 1048 1205380 CARBURETOR.
I NEED A NEW CARBURETOR OR A REBUILDING KIT, ANY SUGGESTIONS?
ebinmaine
Highly recommend to rebuilding your existing carburetor if the throttle shaft is not too loose.
Lincoln at A To Z should be able to fix you up with everything you need.
gwest_ca
One has to watch because Kohler calls a complete carb a kit.
If you open the Fuel System page and go to the bottom (last) of the individual parts on the right the kit is listed as needle and seat 12 521 04-S
https://www.partstree.com/models/ch14-1838-kohler-command-pro-single-engine-made-for-toro-14hp/
