Bill Claffey 1 #1 Posted August 26, 2022 I HAVE A WHEEL HORSE 314-8 TRACTOR WITH A KOHLER COMMAND CH14S ENGINE EQUIPED WITH A WALBRO LMK 43 1048 1205380 CARBURETOR. I NEED A NEW CARBURETOR OR A REBUILDING KIT, ANY SUGGESTIONS? Share this post Link to post Share on other sites
ebinmaine 70,719 #2 Posted August 26, 2022 Highly recommend to rebuilding your existing carburetor if the throttle shaft is not too loose. Lincoln at A To Z should be able to fix you up with everything you need. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #3 Posted August 26, 2022 One has to watch because Kohler calls a complete carb a kit. If you open the Fuel System page and go to the bottom (last) of the individual parts on the right the kit is listed as needle and seat 12 521 04-S https://www.partstree.com/models/ch14-1838-kohler-command-pro-single-engine-made-for-toro-14hp/ Share this post Link to post Share on other sites
