Hampton
Wheel horse tiller for 310-8
Hampton
Looking through market place and seeing a few with a few hours drive, some with extra gears and some not. Curious about what I should be looking for exactly. Hate to buy one and then realize I still need more parts.
squonk
You need the rear axle bracket ,cable and rear rockshaft to lift it idler pulley and bracket and a long honkin belt!
Hampton
I have the clevis hitch and rock shaft to install. The long honkin' belt is on order because it's the same one I need for my mower deck. Appears to be the idler pully, shaft and spring i need.
c-series don
The tiller belt and the mower belts are not the same.
gwest_ca
This is the tiller used in 1985 for the 310-8. The parts list shows all the necessary pieces.
Later tillers will also fit. Earlier ones will work with modifications.
1986-1989 tiller model 07-36TL03
Uses tiller hitch 105543
Rear axle hitch mounts under rear axle
[Drive belt # 1599 (HA x 139.00in 1/2" x 139") If used on later twin-cylinder models use belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1990-1991 tiller model 07-36TL04
[Drive belt # 103635 which has been replaced by # 110265 (1/2" x 141.00")]
1992 tiller model 07-36TL05
1993-2001 2003-2007 tiller model 79370
  • Excellent 1
Hampton
My mower is the 37" I believe which uses the same 110265 belt. However, I may only have a one cylinder so I'll have to check. Still so new to this.
Hampton
Yes and no I think. Mower deck belt for 37" is 110265. It's the same belt for the tiller if I have a twin cylinder motor which i probably don't have with just 10hp.
Edited by Hampton
