Snoopy11 5,714 #1 Posted August 23, 2022 I picked this mower up the other day along with the Tecumseh hh120. I got this mower running after replacing the fuel lines, cleaning the fuel tank, new fuel filter, new spark plug, fresh gas... crank crank. DUD... The clock spring on the pull start system broke. Take all that apart, put in a new clock spring... wind... wind... wind... put it all back together... crank... FIRE on the first pull. 100_2043.MOV Don 4 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #2 Posted August 24, 2022 Does my rjs Briggs have a clock spring if so thanks for the info Share this post Link to post Share on other sites
Snoopy11 5,714 #3 Posted August 24, 2022 2 minutes ago, The Freightliner Guy said: Does my rjs Briggs have a clock spring if so thanks for the info If it is pull start, then it has a clock spring. You can usually rewind them if they haven't broken off too short... Don 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #4 Posted August 24, 2022 Ok thanks now I have something else to check out thanks Share this post Link to post Share on other sites
