Monstrosity
Snowblower
Monstrosity
So I've dissected my single stage wheel horse snowthrower I thought to have found a sprocket and chain kit for it in the past. But coming up short of finding it again would anyone have a link for it??
ri702bill
My early (1963) single stage used the #41 narrow chain & sprockets....
peter lena
@Monstrosity  use some open gear / chain lubricant  on that chain , never let it dry out , also do some idler pulley , tension frame  , detailing , just behind  the blade , front of frame area , often neglected , if you lubricate the spring pull tension area , the pulleys will respond and spin up easier / quicker ,  you could also add  a plastic snow slide , gasket under the chute base area , remove chute , place on plastic , marker pen , size to size gasket , super lube , aerosol , swing with out effort ,  bolt on a couple of electrical lugs , in place of the original  cable mount  side clips , much stronger and cleaner . other things you can also do . only if you are interested , pete
