Monstrosity 1,146 #1 Posted August 22, 2022 So I've dissected my single stage wheel horse snowthrower I thought to have found a sprocket and chain kit for it in the past. But coming up short of finding it again would anyone have a link for it?? Share this post Link to post Share on other sites
squonk 42,522 #2 Posted August 22, 2022 # 40 roller chain and sprockets at Tractor Supply https://www.tractorsupply.com/tsc/product/weasler-roller-chain-idler-sprocket-40-chain-17-teeth-bore-1-2?cm_vc=-10005 3 Share this post Link to post Share on other sites
ri702bill 8,967 #3 Posted August 22, 2022 My early (1963) single stage used the #41 narrow chain & sprockets.... Share this post Link to post Share on other sites
peter lena 9,087 #4 Posted August 22, 2022 @Monstrosity use some open gear / chain lubricant on that chain , never let it dry out , also do some idler pulley , tension frame , detailing , just behind the blade , front of frame area , often neglected , if you lubricate the spring pull tension area , the pulleys will respond and spin up easier / quicker , you could also add a plastic snow slide , gasket under the chute base area , remove chute , place on plastic , marker pen , size to size gasket , super lube , aerosol , swing with out effort , bolt on a couple of electrical lugs , in place of the original cable mount side clips , much stronger and cleaner . other things you can also do . only if you are interested , pete 1 Share this post Link to post Share on other sites
