DouglasParker
502 with k181 Drive Belt Question
DouglasParker
I’m sure someone else is running this setup tried searching and haven’t found anything different. For the most part says it takes a 70” belt nope no way I’m guessing 72” or 73” anyone else running a setup like this that can confirm belt length.
thanks in advance for your time.
squonk
Does the tractor have the original engine? Pics would be helpful.
wallfish
:WRS:
Since a 70" belt is the correct belt length for those tractors, the engine change to an 8hp Kohler changed something. Just add a longer belt if that's what it needs and will work with clutching
Edited by wallfish
squonk
Why didn't I realize the 181 isn't original? :confusion-seeingstars:
  • Haha 2
Pullstart
What size is the pulley on the K-181?  Using my stock pulley on my K-181 equipped 502, I run a stock belt.
ri702bill
Would be the same as a 702 IF the pulley diameter is the same  as a 7 hp.....
DouglasParker
I’ll go measure pulleys on motor and trans plus clutch idler I can get a 70 on it but it’s so tight there is no room to mover pedal
DouglasParker
measured with calipers engine pulley 1.5” Id  clutch tensior pulley 2” Id  transmission pulley 3” Id
wallfish
You should turn that engine pulley around so the groove is tighter to the block and it will line up better with the others. That should give ya a little more.
The frame F plate looks tight to the trans but make sure there aren't any repairs that space it out or that it's not cracked which is a common occurance
Try loosening the engine bolts and slide it back as much as possible then tighten
IDK if all of that is enough but something is a miss.
The original Techumseh would've had an engine plate under it to raise the crank PTO shaft so the 8 hp Kohler bolted directly to the frame should put it exactly where that one was.
DouglasParker
Just slapped engine pulley on for show in the picture  I’m gonna get a longer belt tomorrow the 70” the pedal is all the way like it’s pushed in so my dilemma is do just 1” longer or jump to 2” longer that way the pedal will have alot of play, just not sure if 1” gives a lot, I don’t like the guessing game my 1276 all belts fit like they should my c120 and 520 all no problems just this thing smh and on a side note noticed the head gasket was leaking I thought no problem I have a extra gasket, head bolt by exhaust snaps off spent few hours dealing with that and then my gasket is for a k30 I give up for the week mess with it more next weekend.
wallfish
HEY, did we go to the same school? LOL
If you have a tractor supply store near you, buy'm both. Use the one that fits the best and take the other one back later (when ya break something else and need a part.)
Thompson1276
I’m running a 72 on my 1276 but 73 was too loose and 72 still dosnt feel right yet but my pulley has a small dent that’s lifts it up a 1/2 inch it was a Kevlar belt make sure you also get a Kevlar belt they will stretch if you don’t but it was 3/8 by 72
wallfish
WH did not use 3/8" drive belts so yours should be a 1/2" wide belt for 1276. Maybe that's the problem you're having with it. Any damage to the pulleys can cause erratic shaking so that may be why it doesn't feel right to you. Hydros like yours don't use clutching or a pedal like the manual trans on this 502 does so technically you shouldn't feel much of anything. The tension idler or mechanism holes for the fasteners can get worn and allow for some shaking but going through it thoroughly to " tighten things up" and make any necessary repairs should take care of most of that. They do tend to vibrate the tensioner a little
DouglasParker
Edited by DouglasParker
DouglasParker
Well 72” was way way to big. I rekon tomorrow I’ll try to fit a 71  Idk maybe I got a mismarked 70” the first time but it would be a first for me
Thompson1276
Prob explains why the old belt was torn sat in the groove perfectly in transmission but not fully on the engine pulley
Thompson1276
Mine used the parking brake spring tension as the tensioner to tension the belt as gown but yeah that’s the old belt the new one was about a good 4 -6 inches higher
953 nut
You have an automatic transmission, the one in question is a gear drive transmission, Wheel Horse didn't offer an automatic in 1962.
Thompson1276
Hooks the same as my Sears that is a 6 Speed Split accept the tensioner is. Near the engine not transmission and upsidedown spring tension wise it tensions upwards
