josephbruce11212@gmail.co
Valve stems?
Does anyone have the valve stem size for 60's rims?
Handy Don
Sorry, I'm fully tubed! :hide:
8ntruck
The one that fits?
Having been an engineer in the automotive wheel industry for my 40 year carrier, I should know the size.  But, I don't.  It was always specified by the customer, and other than when moving from tubes to tubeless wheels while I was still in grade school, I don't remember any changes.
The Tire and Rim Association is the keeper of standards to make sure tires, rims, tubes, valve stems, and wheel weights all work together regardless of who built the component.  Try checking their web site?
1 minute ago, 8ntruck said:
The one that fits?
Good to know, I will check the site.
Pullstart
Seems like .410 and .620 or something funky.  Just less than 1/2” and just less than 5/8”
What size tube do you run?
rmaynard
I have adapters to make the .410 fit in the .625 holes. I can send you a couple, but..... I'm on vacation in Florida and won't be home until Friday. These allow the smaller stems on tubes to fit larger holes in rims. They are not for tubeless tires.
Edited by rmaynard
Snoopy11
Here is what I use. Works AWESOME!
https://www.amazon.com/VTR-TR-416-S-Outer-Mount-Metal/dp/B01BRVCQ7K/ref=sr_1_3?crid=2VX3FTBKS91DP&keywords=screw+in+valve+stem&qid=1660757527&sprefix=screw+in+valve+stem%2Caps%2C1349&sr=8-3
Don
Snoopy11
P.S. @josephbruce11212@gmail.co... those valve stems that I posted above fit .453" and .625" rim holes...  :banana-dance:
AND... to top it off... they look KILLER!!! :eusa-violin:
Don
Jeff-C175
3 minutes ago, Snoopy11 said:
what I use
Would they work for both size holes Don?  I bought a pair of rear wheels from Lincoln last year and one had the .453 and the other had the .625 sizes.
Quote
NEVER MIND!  LOL!
Edited by Jeff-C175
Snoopy11
Yes sir... they are listed to work for both size holes, and I can personally verify that they do work for both size holes.  :greetings-waveyellow:
Don
Snoopy11
4 minutes ago, Jeff-C175 said:
NEVER MIND!  LOL!
You'd be surprised how fast a grad student can type... :laughing-rolling::confusion-helpsos::laughing-rolling:
Don
  • Haha 1
Handy Don
Nothing fancy. 6x12 extra heavy duty in the rear (they were Silvertowns and in there when I got the tractor--I suspect original equipment); 4x8 heavy duty in the front (new and matches to tire sizes)
For my use case (mowing ~¼ acre plus some towing and show touring), I'm expecting never to mess with those tires again as long as own this tractor.
Don
Those are the ones I ordered....not holding air...hmmm
That'd be cool! appreciate it!
Ed Kennell
Should the rubber washer be on the inside?
  • Haha 1
It came with 2 different rubber washer dependent on hole size. I installed with the first washer correctly. It leaked, so I was hoping if I added the other sized washer under the nut washer it would aid and seal.....it did not.
  • Sad 1
I'm pretty sure its the bead leaking and not the valve stem....
Snoopy11
Yeah, I have used those things to death without issue... :eusa-think:
Don
Handy Don
Should be steel and rubber washers on each side for that style, right?
Spray some soapy water on the bead to see where it's coming out (or just throw the wheel and tire into the swimming pool).
Edited by Handy Don
  • Haha 1
Jeff-C175
You can always use soapy water to spot leaks!
lynnmor
I use those on my travel trailer.  They can easily be under or over tightened, it appears that you may have squashed the rubber too much.  A bit of tire mounting lube on the rubbers allows them to better conform to the wheel.
953 nut
Xtra-Seal - Tire - Bead Sealer Flammable 32Oz (TI250)
  • Like 4
It should be possible to push the tires off the bead, clean with wire brush, bead sealer and fill, right? I'm not at all looking forward to having to remove the tires... if that is needed.
