Hampton 95 #1 Posted August 17, 2022 Only been on here a couple weeks and it's been a very pleasant experience. 2 3 1 Share this post Link to post Share on other sites
peter lena 8,637 #2 Posted August 17, 2022 @Hampton what are you working on ? new / old / custom ? just asking , pete Share this post Link to post Share on other sites
Hampton 95 #3 Posted August 17, 2022 3 minutes ago, peter lena said: @Hampton what are you working on ? new / old / custom ? just asking , pete Just got a 310-8 trying to get set up to use. Have clevis hitch, rock shaft and mower belt on order. 1 Share this post Link to post Share on other sites
peter lena 8,637 #4 Posted August 17, 2022 @Hampton thanks for the reply , done a basic baseline service? thats a verification of what works and doesn't, rusty / neglected areas ? thorough lubrication redo ? carb bowl removal for a debris check ? milky trans fluid? torn shift boot ? rusty linkage areas , stiff clutch linkage ? questions asked are only basic stuff , any one of them can give you fits , how about corroded wiring ? erratic electrical ? seams over whelming , its not , if you go from spot to spot , correct , verify , go on . we have all been there , pete Share this post Link to post Share on other sites
Hampton 95 #5 Posted August 17, 2022 I have a bit to do with it. All I know right now it runs, moves and shifts. Trans fluid is a little milky so I understand that will be an issue but if I can get what I need done before winter I can work on that later. 2 Share this post Link to post Share on other sites
peter lena 8,637 #6 Posted August 17, 2022 @Hampton , https://www.bing.com/images/search?view=detailV2&ccid=kw9R8RL1&id=2EA72718E98F1BE4E27521F1C1343FDF5AB13B8A&thid=OIP.kw9R8RL1-88BJn-- trans fluid drainage point picture . more thorough drainage if the trans has just been used / driven around , pictures and related details are on that site . allen plug on very bottom of trans , 2 qts of 75- 90 gear oil . jack up front end for more thorough drainage ,pete Share this post Link to post Share on other sites
peter lena 8,637 #7 Posted August 17, 2022 @HamptonT also get a shift boot , vendors on wheel horse site , or on line . pete 1 Share this post Link to post Share on other sites
Sparky-(Admin) 21,339 #8 Posted August 17, 2022 6 hours ago, Hampton said: Only been on here a couple weeks and it's been a very pleasant experience. Glad to hear your happy with the forum! 2 Share this post Link to post Share on other sites
EB-80/8inPA 1,655 #9 Posted August 17, 2022 7 hours ago, Hampton said: Only been on here a couple weeks and it's been a very pleasant experience. Sticking around awhile may eventually adjust that. Just kidding, of course. The folks on here are the best. 1 Share this post Link to post Share on other sites
953 nut 55,324 #10 Posted August 17, 2022 We all like to be helpful so please don't hesitate to ask any questions you may have. 1 Share this post Link to post Share on other sites
