Target 1 #1 Posted August 14, 2022 I own a WH 312-8 with 42-inch side discharge deck. Will a 48-inch deck fit this tractor? I saw that the cutting height adjustment for the 48-inch deck is on left and my 42-inch deck the adjustment is on the right. Does it use the same belt from the PTO? Mowing decks are hard to find. Share this post Link to post Share on other sites
daveoman1966 3,807 #2 Posted August 14, 2022 The Toro MPV sez..yes A 48" deck will hang on the 312-8 48" Side Discharge Mower Will accept Vac Bagger 07-4XVC01/79301. Current Model Available: 15-48SC03/78361 Original Model Supersedes To: 15-48SC03 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #3 Posted August 14, 2022 48" belts are on this page 42" side discharge belts Share this post Link to post Share on other sites
Ed Kennell 40,485 #4 Posted August 14, 2022 4 hours ago, Target said: Will a 48-inch deck fit this tractor? Sure will. You may have to mow in a lower gear than when using the 42". It takes more torque to spin the longer blades. Keep the mule drive and the PTO tight to prevent any slippage. to the Share this post Link to post Share on other sites
