peter lena 8,589 #1 Posted August 13, 2022 https://www.amazon.com/Titan-Casters-Waxman-4383555-Replacement/dp/B07WW24B1C/ref=pd_lpo_3?pd_rd_i=B07WW24B1C&th=1 installed these , not long ago , been testing trying looking at how they work , the lawn slide grip is a non issue , thats what you want , metal wheel with 2 push out bearings , semi sealed , so was able to add lubricant by hand , like old school packing , red grease aerosol can also be used , no heat stress involved , just solid lube . definitely much better deck discharge on my R/D decks , probably gained about 1" , no problems , most of my usage is on grass , very little driveway turning , but very shallow tread makes for easy side slide . typical testing for me , put the hours on any change I make , so if I tell you it works .it does . like summer grass higher , but with the drought we are in , its mostly all brown . just some testing results , also picked up another set for my other deck . pete 2 Share this post Link to post Share on other sites
ri702bill 8,296 #2 Posted August 13, 2022 With the green "Slippery Pete" grease, no doubt.... 2 Share this post Link to post Share on other sites
Bill D 1,915 #3 Posted August 13, 2022 1 hour ago, peter lena said: https://www.amazon.com/Titan-Casters-Waxman-4383555-Replacement/dp/B07WW24B1C/ref=pd_lpo_3?pd_rd_i=B07WW24B1C&th=1 installed these , not long ago , been testing trying looking at how they work , the lawn slide grip is a non issue , thats what you want , metal wheel with 2 push out bearings , semi sealed , so was able to add lubricant by hand , like old school packing , red grease aerosol can also be used , no heat stress involved , just solid lube . definitely much better deck discharge on my R/D decks , probably gained about 1" , no problems , most of my usage is on grass , very little driveway turning , but very shallow tread makes for easy side slide . typical testing for me , put the hours on any change I make , so if I tell you it works .it does . like summer grass higher , but with the drought we are in , its mostly all brown . just some testing results , also picked up another set for my other deck . pete Make life easy on yourself Pete. Remove the bearings, then drill and tap a hole in the wheel for a grease fitting. Remove any chips with a vacuum and compressed air. Reinstall the bearings and pump the wheel full of grease just like the stock Wheel Horse deck wheels. 1 Share this post Link to post Share on other sites
peter lena 8,589 #4 Posted August 13, 2022 @ri702bill yes got some in those bearings , the original w/h horse wheels were very good ,the rubber would just give up after 30 years ! thing I really notice with the green , is its staying power, even in the mule drive bearings , they get very hot , which causes lubrication failure / noisy , whining bearings , very nice to have no noise /bearing issues since change over . anything related to my mower drive set up , pto lever to anything on the deck, goes green . lots of hours , many starts , it just makes sense . green , pete 1 Share this post Link to post Share on other sites
peter lena 8,589 #5 Posted August 13, 2022 @Bill D just ordered another set of wheels, might give that a test / trial , pete Share this post Link to post Share on other sites
skrusins 128 #6 Posted August 14, 2022 I'm glad to see that this is working for those who want to try. I have used 7inch plastic lawn mower in the past couple years. They worked, but didn't last that long. Share this post Link to post Share on other sites
