GreenMntRanger
414-8 brake repair question
GreenMntRanger
How difficult is it to replace the the brake lining? Found mine on the lawn after I mowed HAHAHA
Handy Don
Not difficult to replace either the liner or the complete brake band.
@rmaynard sells liners.
@76c12091520h has NOS and refurbished bands
Other vendors in "Classifieds/Vendors" topics may have them as well
GreenMntRanger
Sorry if this is a foolish question, but hat would be the easiest way to access the brake assembly?
gwest_ca
Just remove the left rear wheel and tire.
GreenMntRanger
Thanks you
ri702bill
Definetly check the condition of the steel band the brake material was bonded to. Mine on the C81, when I got it, looked like swiss cheese. Bit the bullet and got a new one from my Toro dealer - $79 as I recall, better part of 10 years ago... do it once, do it to last....
Edited by ri702bill
rmaynard
Last that I checked, the 9353 brake band assembly was over $100.00. That's quite the bullet to bite.
  • Sad 1
peter lena
@GreenMntRanger  have any conveyor belt material ?  lasts forever , cut it with tin snips , use a silicone glue on inside of band to hold material , once it takes a set , you are good , pete
peter lena
@GreenMntRanger  often refer to a different source / idea for a repair , coming to the end of my stash of goodies , as a millwright , was regularly put into a , we need this fixed right now ,situation , so thats how I  refer to a possible fix. obviousely , there is an exact part for your problem ,  what ever is easiest  and suits you , is also in that repair , pete
Snoopy11
Absolutely.
I did an experiment with my brake band. I cleaned it VERY WELL... and since I didn't have any silicone... I used a hot glue gun with Gorilla glue sticks... :P
Gorilla Dual-Temp Mini Hot Glue Gun | Grand & Toy
Believe it or not, that worked excellently for me. I would do that again in a heartbeat, rather than wait for regular messy silicone caulk to dry... :banana-dance:
I don't know what @rmaynard thinks about that... but I swear by it... :D
Don
peter lena
@Snoopy11  snoop ,was going to suggest you thinking outside the box ,but in your case , you are so far  outside , we would have to send out a search team !  good idea . pete
  • Haha 2
rmaynard
I think that unless you get the lining on and press it tightly to the band before the glue dries, it could end up lumpy or uneven. Then, the very nature of hot glue is that it melts. Brakes can  get very hot when used heavily. Heat will re-melt the glue and the lining could come loose.
Just my :twocents-twocents: worth.
Snoopy11
Well... so far... it has held up well.
If anything negative happens... I will come back into this thread or make another thread about my idea... and let everyone know...
@rmaynard... In my case, my glue gun can get REALLY hot, so I have a good amount of time to put the band on before it dries... which helped keep it from getting lumpy!
Don
Jeff-C175
Use a heat gun to get the steel band and the lining gudenhot before gluing and you buy yourself even more time.
My automatic manchines rarely get the pedal pushed down to stop.  Maybe a manual would need more...
I think the chance of them getting hot enough to re-melt the glue would be rather slim ?
Handy Don
To me, it isn't the possibility of melting.The versions of the glue you get at the hardware/big box/hobby/craft stores just don't adhere well to metallic surfaces, especially smooth ones. Of course, it is possible to get industrial hot glues but by then Bob's recommended system is just as easy.
Snoopy11
I'll put it this way...
I have put it through various testing... basically braking the hell out of it... downhill, pulling hundreds of pounds of dirt downhill holding the brake... without issue.
But my testing continues just the same.
Don
Snoopy11
@GreenMntRanger... can we see any pictures of your brake lining?
You may not need to replace it... may just need to re-glue it back in...
Don
GreenMntRanger
Don
It's for the most part intact but super brittle. Knowing the former owner, it is safe to say it's OEM circa 1987
Snoopy11
4 minutes ago, GreenMntRanger said:
super brittle
Yeppers... that's gonna need a replacement...
Don
