Wheel Horse Willy
Stalls after running
Wheel Horse Willy
Hey all!
New to the page so first, thank you for the add! I’ve been a Wheel Horse fan for over 20 years since my old neighbor and his grandfather got me hooked! After many years of searching, I finally got a hold of a real one! I did have a Toro-Wheel Horse….212-? It was a good machine but gave it to a friend for a back up. I picked up a 1988 , 252-H and it’s clean! A little rust but the red shines up nice! Everything is original. Belts, tires, bulbs….fuel line and filter have been replaced. I started cutting my lawn the day I brought it home and since my yard is a little hilly, thought maybe the sensor under the seat was the culprit for the stall but it seems to depend how warm it is out? I managed to cut the entire back yard today and just as I was pulling it into the shed, it sputtered and died. It fires right up and runs great when cold! Even seems fine after a while running but after reading a few posts, I might try to replace the spark plug. The one thing I did not check. This was an issue with a 20+ year old Echo weed wacker I had so I will try that. If anyone has any other ideas/info, I would appreciate it! Thank you and have a great evening!
Pullstart
:text-welcomeconfetti:  I’m not too familiar with these vertical shaft rigs, but I’d suggest cracking the gas cap when it stalls and see if you can get it to fire back up.  That would mean a plugged vent.  Also, it could be the coil gets hot and dies too.
  • Like 6
953 nut
:WRS:                                  :text-yeahthat:
As gas is being used a slight vacuum will develop in the fuel tank unless the vent is working, Too much vacuum and no flow of fuel.
  • Like 3
edgro
:text-welcomewave:
Also possible plugged internal screen on fuel fitting at tank. Not sure if your mower has one, I had a similar problem on a 414-8, and the screen was plugged. Replaced with unscreened fitting and external filter.
Wheel Horse Willy
Wheel Horse Willy
Thank you, I will try the gas cap.
27 minutes ago, edgro said:
:text-welcomewave:
10-4. It’s a full tank but I’ll drain down and check for a screen
Wheel Horse Willy
Thank you. I will drain the tank and check for internal screen
Wheel Horse Willy
Good stuff! Thank you all. I’ll update once I get it figured out.
gwest_ca
You would be surprised how much junk collects in the tank in 34 years. As the fuel is being drawn into the line this junk gradually plugs the screen and will float away from the screen when flow stops.
See if gravity will completely drain the tank with a constant flow. If not time to clean.
  • Like 4
Pullstart
Once again, :text-welcomeconfetti:  this is the kind of help these folks give with most every challenge working on an old tractor!
  • Excellent 1
Wheel Horse Willy
I will try that as well. I guess i was just too excited to get that Wheel Horse cut in the yard and should have really gone over everything. I am the 3rd owner and it was well taken care of.
  • Similar Content
    • cJ_3D
      By cJ_3D
      Hello helpful Wheel Horse enthusiasts!
      Maybe you all could help me figure something out. I don't think I am installing the mower deck properly on my 1989 252-H and I don't know if the PTO clutch is adjusted right.
      So referencing this image here from the service manual for the mower deck (37"):
      What exactly am I doing with this adjustment knob and how does it fit into this piece?
      Also for the PTO clutch where am I sticking the feeler gauge exactly and do I need to do all 3 springs? Or does adjusting the one in the manual adjust all three?
      Much obliged for the help!
      CJ
    • cJ_3D
      By cJ_3D
      Hello everyone!
      Thought I would post a new thread on this as I wasn't able to find the information I was looking for. But I'm trying to get this drive belt on my 252-H and no matter what I try I can't get it on. I got a 1/2" x 76" so I know its the correct size belt. I followed the steps outlined in the manual which I've attached, and is shown on page 15. So I loosened the cross bar nuts and the flat idler adjustment pulley. And followed the routing from this guide: http://outdoorpowerinfo.com/repairs/wheel_horse_hydro_252-h_drive_belt.asp
      I just can't get enough slack on it to get it over the engine pulley! Right now it's pinched up between the body and the pulley so possibly I can't get enough leverage, do I need to somehow work it from below the pulley? Doesn't help the pulley keeps coming off the shaft so I have it propped up using a scissor jack which is cumbersome to work around. I don't have a shop or anyway I can think of to safely stand the mower up and not sure about tipping it on it's side. Anyone who has done this particular belt on this mower before have any tips or suggestions for how to get this thing on?
      Thanks for the help friends!
      CJ
      492-4003 Eaton 7 & Peerless 1320 SM.pdf
    • MachXXII
      By MachXXII
      Does anyone know what battery a 1988 252-H needs. I looked around and couldn’t really find an answer. Thanks
    • MachXXII
      By MachXXII
      I’m trying to restore my grandfathers old 252-H to use around my property. The tires are shot and the rims aren’t too far behind. Anyone have any recommendations for rims and tires that would fit well on it?
      right now it has 22 x 7.50 - 12 on the back and 15 x 6 - 6 on the front.
