857lover
867 looses power
Snoopy11
1 minute ago, 857lover said:
i’ve went down a inch and it’s wayyy to small
Not trying to be an A-hole... but that is nonsensical. :huh:
Look here, I overlooked Mike's comment, but it is very telling...
5 hours ago, squonk said:
the height the idler pulley is in this picture tells me the belt is now too long for this set up
AND... to back that up with a picture that I also overlooked...
In my opinion... it looks like you could go down 2 inches, and it would still not be perfect... :confusion-confused:
I guess I could always break out some of my belts and machines and prove this point... but I sure hope that isn't necessary... :eusa-think:
Don
oldlineman
I would suggest to do what Pullstart and Jim have mentioned and get good original mounting location for the engine and go from there.
857lover
Don
i went down a size and it grinds everytime i try and put it in even pushing on the clutch as hard as possible
Snoopy11
You have no belt guards on the engine so I fully expect that to be the case.
May we have a picture of the pulley system with the smaller belt...?
Don
Snoopy11
That is a REALLY old picture, but you can see my belt guards in this picture. Without those on the engine pulley, my transmission would grind...
Don
Snoopy11
One other thing you need to know...
Once you get everything in working order, and get the correct size belt on... the tab on the clutch pulley needs to be bent inward a tad bit... as it is WAY too far out in this picture...
It needs to be bent in here... you want just enough room inbetween the tab and the pulley to get the belt in and out without having to bend the tab at all...
0DF2E2E1-FB95-4D91-9A7E-7BFBDE9EE090.jpeg.6b820ca01bea9e066ece4f8bf6d04c8d.jpeg.d2bf59bcb958b82bab599445cc3f09ef.jpeg
Don
squonk
Watch the video I posted
