Dieseltu 26 #1 Posted August 8, 2022 (edited) Good morning. I got the 67 856. Its got electric start and a battery. Does that mean it charges up, with an alternator while its running or I have to keep it charged up. ? I havn't seen an alternator or generator yet. And does this thing have a fuel pump or is it gravity feed. I see a hose going to the carb. I keep hearing guys talking about fuel pumps. Thanks Vern Now I know its a 66. From the manuals Thanks Edited August 8, 2022 by Dieseltu Share this post Link to post Share on other sites
squonk 41,650 #2 Posted August 8, 2022 (edited) The engine on your tractor isn't stock so there is no telling what's on it. The original Kohler had a starter generator and a fuel pump. It looked like this Fuel pump Edited August 8, 2022 by squonk 2 Share this post Link to post Share on other sites
Dieseltu 26 #3 Posted August 8, 2022 Im not familiar with 8 horse briggs. i have 6.5 and 5 horse and they gravity feed . Im gonna guess its A briggs and its gravity feed with a float bowl and pin then. What about charging. Share this post Link to post Share on other sites
squonk 41,650 #4 Posted August 8, 2022 1 minute ago, Dieseltu said: Im not familiar with 8 horse briggs. i have 6.5 and 5 horse and they gravity feed . Im gonna guess its A briggs and its gravity feed with a float bowl and pin then. What about charging. Any small wires coming out of the engine shroud? Share this post Link to post Share on other sites
Dieseltu 26 #5 Posted August 8, 2022 Yes there is. I found a worn through small wire rubbed on the engine shroud and I ungrounded it. Have no idea where it goes. Share this post Link to post Share on other sites
squonk 41,650 #6 Posted August 8, 2022 That is probably a magneto kill wire since your coil wire goes into the shroud as well. I think if there are no other wires coming out of the shroud there is no charging system on it. pulling the shroud off would confirm if there is no charging coils there. 1 Share this post Link to post Share on other sites
pfrederi 18,016 #7 Posted August 8, 2022 Stamped on the top of the engine air shroud look for Model Type and Code numbers. then we can figure out what type ...if any..charging system it had. 1 Share this post Link to post Share on other sites
