Olsi 1 #1 Posted August 8, 2022 Trying to change drive belt on Toro wheelhorse 268H, I’m having no luck. If anybody done it and how? Thanks in advance 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #3 Posted August 8, 2022 Welcome to Red Square Perhaps the service manual will help. 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,241 #4 Posted August 8, 2022 Tuff Torq belt is in section 3 Hydro-gear belt is in section 4 1 Share this post Link to post Share on other sites
RLA 1 #5 Posted September 1, 2022 Just seen your query. I have done 2 by the same method as Taryl on you tube !! All you do is if it's got a lot of petrol in, put plastic film under the filler cap and screw it back on. If fuel is low no problem. Remove the deck, and stand the tractor on it's rear. I use a small chain block off a simple scaffold frame, but a roof beam in a garage will do. It is a fiddly job but so much easier than doing it underneath with the tractor on axle stands and blocks. Share this post Link to post Share on other sites
