41chevy 74 #1 Posted August 5, 2022 Could I get some trans pictures showing 1976 b 80 8 speed ( or similar ) with the belt guard off? Also OEM belt part # for the 1976. Thx Share this post Link to post Share on other sites
953 nut 55,744 #2 Posted August 5, 2022 Here is a picture from @RustyGold's thread he has going. The belt on your '76 B-80 8 speed should be #7473 which is a 5L-820 belt. 3 Share this post Link to post Share on other sites
41chevy 74 #3 Posted August 5, 2022 I couldn’t see the spring could you point it out? Share this post Link to post Share on other sites
953 nut 55,744 #4 Posted August 5, 2022 11 minutes ago, 41chevy said: I couldn’t see the spring could you point it out? The spring is on the other side of the tractor, it runs from the rear axle housing to the lever on the clutch cross rod. 1 Share this post Link to post Share on other sites
41chevy 74 #5 Posted August 6, 2022 27 minutes ago, 953 nut said: The spring is on the other side of the tractor, it runs from the rear axle housing to the lever on the clutch cross rod. Thank you. 1 Share this post Link to post Share on other sites
