Jeff-C175
DIY wheel weights - disc brakes !
peter lena
@Jeff-C175  interesting idea, local  bone/ scrap yard near me always has piles of brake rotors  near the front of yard. .might have to do some snoopin  and planning , pete
  • Like 4
davem1111
Can't wait to see them on a tractor. :D  You gonna paint them?
Pullstart
Nice work!
OutdoorEnvy
Nicely done Jeff!  I may borrow your idea and go with your 8" height suggestion!  Thanks for the post!
Jeff-C175
Making paint stick to HDPE in any sort of permanent fashion is nearly impossible.  Soooo, I think I'm not even going to try.  Unless I have some "head cheese" cans of paint leftover... maybe I'll give it a shot.
I have read that you can 'flame treat' HDPE and make paint stick... I might try that on a test piece.
Jeff-C175
I'll test fit them in a week or two when the concrete is more dry.
roadapples
Could try to find some red buckets instead of yellow ...:ychain:
   Nice job...
Jeff-C175
   Nice job...
I only had a choice of blue which was in real bad shape, green... Uhhh, no, thank you, or yellow.  So I went the least offensive route possible!
I am going to look into a way to paint them but I don't have high hopes!
Snoopy11
Lookin' better than mine, Jeff... :teasing-poke:
:laughing-rolling::confusion-helpsos::laughing-rolling:
Don
  • Sad 2
Jeff-C175
I wanted to thank you for inspiring me to finally do something I've been thinking about for a long time, and showing me how not to do it! ;)
ebinmaine
Nice work Sir.
I tried to tell 'im!!
  • Haha 4
sjoemie himself
@Jeff-C175 if you don't mind me asking, why leave the buckets on? I'm assuming for better structural integrity but there may be other reasons..
Jeff-C175
Of course I don't mind!
I think the first was to minimize damage to the wheels when installing / removing the weights.  The smooth plastic surface is far less likely to scrape up the paint.
Handling them is maybe somewhat easier due to not having to handle coarse concrete.
And yes, structural integrity does play into it quite a bit.  Since there isn't a whole bunch of room between the edges of the brake drum and the edge of the bucket, there wouldn't be a lot of material holding the concrete together at that point.  I would be possible that the concrete could break at those points.
sjoemie himself
Yep, makes perfect sense! Thanks for explaining.
My thought regarding the paint was rubberized paint or bedliner or something in that direction. That's why I thought lose the bucket and stick it together with bedliner or similar.
But even bedliner won't hold the brakediscs in the concrete I think.
Another thought that came to mind, use a metal (paint-) bucket? :eusa-think:
All this being said, I don't want to undermine your idea ofcourse.
Greetings from the Netherlands, Mark
Snoopy11
As a student of this thread... hoping to eventually make my own weights in the near future... metal sounds like a very good idea... one that I am going to ponder... :ph34r:
Don
Jeff-C175
But even bedliner won't hold the brake discs in the concrete I think.
All this being said, I don't want to undermine your idea of course.
Hi Mark,
Not so worried about the disc coming loose from the top since the concrete fills the center and there's a big hole which should bond it well.  The drum in the bottom though, there's likely not enough to hold that.
I did consider metal as well... but one of my goals was to not have to purchase anything except the concrete and that goal was met.  That said, I did hit the home goods stores looking for something to use that would fit without modification and everything I looked at was either too big or too small... and I considered every round object in the stores!  ;)
Now that you mention it though... a rubberized bed liner might just stick to the HDPE plastic.  I've yet to try any tests, but one thing I am going to try is the 'flame treatment' on the material and hit it with some paint to see what happens.  I dearly would love to get rid of the yellow!
sjoemie himself
Kind of a sport to keep cost low on things like this. I like and practice the same method :handgestures-thumbupright:
Never heard of 'flame treatment' but curious to see how that works.
HDPE is a tricky substance to paint for sure. The only advantage that you have is that the material is fixed in place. Not so much to worry about in terms of the HDPE wanting to flex.
