Thompson1276
Parking brake knob broke
Thompson1276
I have a 1966 wheel horse 1276 the parking brake knob broke and I cannot find one anywhere the same style it runs a stove bolt between it but is plastic the one side broke from use if anyone can help that would be great thank you
daveoman1966
New from dealers...2 pc.  Part 8693 and part 8722
Find them here:  https://www.rcpw.com/lookup/#
Be sure to select 'Toro Consumer' for parts lookup.
Thompson1276
It’s a rare tractor only 800 made so I found nothin but I might have to find a junkyard of wheel horses thanks for that anyways man worth a try
Jeff-C175
18 minutes ago, Thompson1276 said:
I found nothin
You looked on the site that Dave posted?  This isn't what you need?
Kinda pricey I guess.
I made my own.  Aluminum... adds a little 'bling'
Damien Walker
Would be a fairly straightforward lathe project or even 3D printer...though the finish quality might not be quite so good with the latter.
Other than the colour, it also looks near identical to the knobs on the hydro clutch lever on the C-175....that might might be much more common.
Lee1977
If you just need something to pull it up with plastic or nylon 1/4" pipe.
