jake3
Wheel Horse 211-4 repair needed
jake3
I just purchased the tractor/mower this week and have found the gear at the end of the steering shaft has been damaged, partially stripped.   It runs fine and  mows but can not steer:confusion-helpsos:. Any ideas for parts or repair?  Have not found any replacement parts yet or used parts.
Jeff-C175
Check our "vendors" forum, in this case call Lincoln at AZ tractors.
  • Like 3
Jeff-C175
Also, look in the "manuals" forum and find the manuals foryour manchine.
Oh, and WELCOME to the forum!
roadapples
:WRS:
953 nut
:WRS:
Unfortunately your 211 is a later model and Toro began to skimp on the quality that Wheel Horse was known for. The steering components do tend to have some weakness. First place to call would be Lincoln at A-Z Tractor, https://a-ztractor.com/. If he hasn't got the parts you need give Joe a call, https://joesoutdoorpower.com/. These are both good reputable dealers.
  • Like 5
Ed Kennell
:text-welcomeconfetti: to the :rs:Jake.        The TORO vertical engine 200 series are a riding lawn mower.   A much lower quality of construction than the Wheel Horse horizontal engine garden tractors.       At $251 for a new steering shaft from TORO, hopefully you can find a good used one from A to Z.    You may want to search for an entire parts tractor that can sometimes be bought for less than a single part.
Good luck
  • Like 5
