Thompson1276
Leaded Gas
Thompson1276
I’m restoring a 1966 1276 I found the paint had lead in it was getting dizzy just sanding that’s when I thought about it , should I put Lead additives in my gas since it’s when lead gas was still in use , it’s a K301ST from 66 also it says use 90 octane but I only can get 82 and 87 at my local pump will that matter also
squonk
From Brian miller's site:
Lead in gas was actually meant for older (pre-1970) automotive engines because they had soft cast iron valve seats. The cylinder heads were made of cast iron and the seats were cut or ground directly into the head with no hardened inserts. These seats was not heat-treated and would wear when no lead is present in gas. However, the later model automobile engine valve seats (1971-present) are heat-treated and last a lot longer. The seats were still cut or ground in the [cast iron] heads, but are heat-treated. The aluminum automotive heads have heat-treated steel inserts for valve seats. And virtually ALL small engine valve seats come from the factory heat-treated. They are steel inserts, and rarely wear when no lead is present in gas. "
SylvanLakeWH
Hope you were wearing an appropriate mask…?
  • Like 3
  • Excellent 1
Thompson1276
No mask man I been around it for so long I never seen a reason for one at this point
  • Haha 1
  • Confused 1
bc.gold
The info from Millers site is totally incorrect, lead was added to gasoline to prevent engine knock a condition known to destroy engines.
The Man Who Killed Millions and Saved Billions.
  • Excellent 1
peter lena
@Thompson1276  worked in a very macho shop , typically lots of  related workers , millwrights , pipefitters / welders , electronic techs , instrument techs, would scoff at any available protection offered . just did not make sense to me , you could see and smell the environment you were entering, yet the macho way was to tough it out . always had a dust mask in my hard hat webbing, always had ear plugs or  available, or  " ear muffs " in a high , intense level situation . and would not hesitate to suit up to the next stage if needed . even today , always have the push in earplugs in my pocket , very simple shut down to any confining  noise situation . just my own experience , but when you can see your air intake , protect yourself, been there , pete
  • Excellent 3
