Damien Walker 288 #26 Posted May 24, 2023 3 hours ago, kpinnc said: You're thinking is similar to mine. Just direct link to the center rocker. Yes, that's right. I have a spacer between the crank on the pedal and the pushrod and it seems ro work mechanically at least (have yet to trying driving). I'm delayed due to my Heim join supplier sending me metric instead of unf threads and I have yet to work out the return springing. My current thought on the latter is to use coil springs around the push rod...I don't have the room to use Matt's method due to the power steering pipes... How are you doing your return springs? Do we need to shift this to a seperate thread? 1 Share this post Link to post Share on other sites
