josephbruce11212@gmail.co 262 #76 Posted July 27, 2022 10 minutes ago, Snoopy11 said: I have a seat that @davem1111 gave me... it isn't in absolutely horrible shape... but it could use a seat cover... I could include the seat bracket as well. I can get some pictures of it if you are interested? Don That'd be awesome! 1 Share this post Link to post Share on other sites
Snoopy11 5,714 #77 Posted July 27, 2022 Just now, josephbruce11212@gmail.co said: That'd be awesome! Okay, I'll shoot you a PM with some details... Don 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #78 Posted July 27, 2022 BRB, going to see my grandbaby!!! First day home!!! wooooooot 1 3 Share this post Link to post Share on other sites
Snoopy11 5,714 #79 Posted July 27, 2022 1 minute ago, josephbruce11212@gmail.co said: BRB, going to see my grandbaby!!! First day home!!! wooooooot Absolutely! PM sent. Don Share this post Link to post Share on other sites
davem1111 2,030 #80 Posted July 27, 2022 1 hour ago, josephbruce11212@gmail.co said: Not the color I was hoping for.... That's what the fluid in my 416-8 looked like. Rubber shifter boot must have been rotten for years, and the P.O. had left it outside a lot obviously. Looks like you were able to free up the drain plug, which is more than I can say for myself. I took the whole trans off and turn it upside down to drain. Flushed twice, new oil, new shifter boot. Repainted while off. As long as a bunch of metal shavings didn't come out also, you should be fine. 1 1 Share this post Link to post Share on other sites
ebinmaine 67,380 #81 Posted July 27, 2022 2 hours ago, Snoopy11 said: you have the new-to-the-herd checklist, don't you? Here ya go. 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #82 Posted July 27, 2022 Ok, I have flushed the transmission 2x with diesel. Each time color was lighter and no signs of debris. I will flush 2x tomorrow. I do have a question, once flushed, do I need to let the residual diesel evap? Is a little diesel ok with new oil? Should I fill with oil, drain, then refill again? Also, is this Travellers OK for the transmission? 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #83 Posted July 27, 2022 Yeah probably try and flush out as much diesel you can just in case 1 Share this post Link to post Share on other sites
rjg854 11,356 #84 Posted July 28, 2022 In a 4 speed transmission you want 80-90 gear lube. 2 2 Share this post Link to post Share on other sites
Handy Don 12,201 #85 Posted July 28, 2022 This is important. Read the manual. Follow it. Pretty much any 80-90 weight gear lube is fine. Auto Trans Fluid is NOT fine. I hope you've been lifting the front of the tractor (if safe, as much as 24") to help empty the transmission. There is a "hump" across the bottom in the middle that lets a pool collect in front of it. A bit of residual diesel will harm nothing. Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #86 Posted July 28, 2022 26 minutes ago, rjg854 said: In a 4 speed transmission you want 80-90 gear lube. I did read 80-90 gear lube, just was unaware if this equated to that. Thank you! 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #87 Posted July 28, 2022 2 minutes ago, Handy Don said: This is important. Read the manual. Follow it. Pretty much any 80-90 weight gear lube is fine. Auto Trans Fluid is NOT fine. I hope you've been lifting the front of the tractor (if safe, as much as 24") to help empty the transmission. There is a "hump" across the bottom in the middle that lets a pool collect in front of it. A bit of residual diesel will harm nothing. I have been lifting the front, I noticed the hump when I was looking over everything. Thank you again! 2 Share this post Link to post Share on other sites
ebinmaine 67,380 #88 Posted July 28, 2022 3 minutes ago, josephbruce11212@gmail.co said: I did read 80-90 gear lube, just was unaware if this equated to that. Thank you! Hydraulic fluid in a universal form is probably pretty thin. There really should be some sort of designation on that bottle somewhere and you'll likely find it's around 10w or 20w. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #89 Posted July 28, 2022 Is it OK to drive and shift through gears with the diesel in there to aid in the cleaning process? 1 Share this post Link to post Share on other sites
Ed Kennell 38,096 #90 Posted July 28, 2022 1 minute ago, josephbruce11212@gmail.co said: Is it OK to drive and shift through gears with the diesel in there to aid in the cleaning process? Yes , drive it slowly in tight figure eights in all gears. 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #91 Posted July 28, 2022 How is the fuel tank and have you looked into that Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #92 Posted July 28, 2022 2 minutes ago, The Freightliner Guy said: How is the fuel tank and have you looked into that fuel tank looks great...minor, very minimal 1 Share this post Link to post Share on other sites
ebinmaine 67,380 #93 Posted July 28, 2022 25 minutes ago, josephbruce11212@gmail.co said: Is it OK to drive and shift through gears with the diesel in there to aid in the cleaning process? Not only is it okay. It's recommended. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #94 Posted July 28, 2022 rainy days... 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #95 Posted July 28, 2022 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #96 Posted July 28, 2022 Didn't turn out to bad, too bad the under wasn't the top!! (Linseed oiled rags are soaking in water bucket) 3 4 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #97 Posted July 28, 2022 Looking great 1 Share this post Link to post Share on other sites
ebinmaine 67,380 #98 Posted July 28, 2022 1 hour ago, josephbruce11212@gmail.co said: Didn't turn out to bad, too bad the under wasn't the top!! (Linseed oiled rags are soaking in water bucket) If you get bored, stop up to my place. I've ONLY got three tractors that could use this type of attention. 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #99 Posted July 28, 2022 Removed all this junk! 2 Share this post Link to post Share on other sites
Handy Don 12,201 #100 Posted July 28, 2022 Course now that it's all oiled up, you can't drive around wearing your "Sunday go to meetin' clothes" any more 'til you get a real seat. 2 Share this post Link to post Share on other sites
