josephbruce11212@gmail.co 262 #51 Posted July 26, 2022 Well, got to do some more fiddling...the brake isn't releasing the belt enough to be able to shift into gear... 1 Share this post Link to post Share on other sites
953 nut 63,021 #52 Posted July 26, 2022 The manual has a good brake adjustment write up. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #53 Posted July 26, 2022 So the brake does work but when I push the brake the transmission pulley continues to spin? Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #54 Posted July 26, 2022 Also, trying to find a gasket kit for H60 75063B, having no luck, are there any similar engines I could use to find these gaskets? Share this post Link to post Share on other sites
Handy Don 15,190 #55 Posted July 27, 2022 58 minutes ago, josephbruce11212@gmail.co said: So the brake does work but when I push the brake the transmission pulley continues to spin? On these tractors, the drive belt cover is essential. It has a tab on it near the engine pulley that rubs and stops the belt once there is a bit of slack. This assumes that: the tab is there and correctly adjusted, the belt is the correct length, and that the engine pulley "v" channel is clean and smooth. I would hazard a guess that for the head, crankcase, bearing plate plate, and carb intake gaskets any H60 or HH60 build would work. I've had no trouble getting aftermarket carb rebuild kits, though the quality can vary, for sure. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #56 Posted July 27, 2022 (edited) Then that could be part of my problem, I didn't have the belt guard on when I was trying to test drive. I did take a piece of wood wrapped with sand paper to all the pulleys as they spun, they cleaned up pretty well. I was able to find the gasket set finally. The engine sounds good, but the governor seal is shot and spewing oil! I'll have to check the belt length. Thanks Don! Just went and check....tab is intact!! Edited July 27, 2022 by josephbruce11212@gmail.co 3 Share this post Link to post Share on other sites
Handy Don 15,190 #57 Posted July 27, 2022 11 minutes ago, josephbruce11212@gmail.co said: the governor seal is shot and spewing oil I don't think there is a seal for the governor shaft. There should not be enough pressure inside the crankcase to cause oil to spew from ANYWHERE on a buttoned up engine--this is a splash lubricated engine, there is no oil pump. Check, clean, and properly reinstall the crankcase vent. If the crankcase is properly vented, only a badly worn gov shaft would seep oil. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #58 Posted July 27, 2022 The crankcase vent must be plugged solid, it's not seeping oil it's leaking. After thinking about it, I remember seeing it "bubble" out around the govenor shaft as if it was venting through the shaft hole. If the governor shaft was that badly in shape wouldn't the performance of the engine suffer? It runs great, besides that leaking. I will check the crankcase vent and reinstall the belt guard and see if that gets us moving!! Thanks Don, you are a wealth of knowledge!! 1 1 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #59 Posted July 27, 2022 She drives!!!! So EXCITED!!! 3 Share this post Link to post Share on other sites
Snoopy11 5,723 #60 Posted July 27, 2022 (edited) 7 minutes ago, josephbruce11212@gmail.co said: She drives!!!! So EXCITED!!! Just wait, dear sir. You will fall completely in love with your old girl. They may start out as... what some people would consider junk... but once you bond with them... they are really something special. Don Edited July 27, 2022 by Snoopy11 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #61 Posted July 27, 2022 (edited) How fast will it go . Also I love mine even though it doesn’t work because it was my great grandpa Reese’s and that’s the only thing we still have of his is that little rj Edited July 27, 2022 by The Freightliner Guy Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #62 Posted July 27, 2022 1 minute ago, Snoopy11 said: Just wait, dear sir. You will fall completely in love with your old girl. They may start out as... what some people would consider junk... but once you bond with them... they are really something special. Couldn't agree more!! I can't wait to get her cleaned up...keeping the patina. Then she can tell her story! Tear her all down and rebuild her! 2 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #63 Posted July 27, 2022 @The Freightliner Guy 2mph tops teasing....she goes good, a guess...maybe 5 1 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #64 Posted July 27, 2022 3 minutes ago, josephbruce11212@gmail.co said: Tear her all down and rebuild her! I'll ping @peter lena here to offer you some excellent wiring and lubrication advice. @ebinmaine... you have the new-to-the-herd checklist, don't you? Don 1 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #65 Posted July 27, 2022 Gave her a light task.... 6 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #66 Posted July 27, 2022 Have you been driving it with no seat this whole time or anything but the raw metal Share this post Link to post Share on other sites
Handy Don 15,190 #67 Posted July 27, 2022 Looks like you are on the road. Good news. Guess you are looking for a seat, now, too! Just a note on speeds, WH engineers designed all their stock tractors to have speeds appropriate for their intended tasks--mowing, plowing, etc. and, TMK, that was a top speed of around 6 mph (except for the 520-HC, aimed at commercial landscapers, which could cook along at 9-ish). Some folks, of course () have swapped pulleys and done other tweaks to boost speeds. 1 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #68 Posted July 27, 2022 20 minutes ago, The Freightliner Guy said: Have you been driving it with no seat this whole time or anything but the raw metal Raw metal, not so bad 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #69 Posted July 27, 2022 Not the color I was hoping for.... 3 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,363 #70 Posted July 27, 2022 That looks like peanut butter hahaha but also that can’t be to good Share this post Link to post Share on other sites
Snoopy11 5,723 #71 Posted July 27, 2022 2 minutes ago, josephbruce11212@gmail.co said: Not the color I was hoping for.... Well, some people would tell you to run diesel in the transmission to clean it out... I would recommend a tear-down... Don 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #72 Posted July 27, 2022 15 minutes ago, Handy Don said: Guess you are looking for a seat, now, too! Looking for a seat and a front wheel, they are mixed matched. The left front has multiple washers on front and back of wheel. 1 Share this post Link to post Share on other sites
josephbruce11212@gmail.co 262 #73 Posted July 27, 2022 1 minute ago, Snoopy11 said: Well, some people would tell you to run diesel in the transmission to clean it out... I would recommend a tear-down... Don I'll probably try to clean it a bit, but it will be tore down and rebuilt at a point. 1 Share this post Link to post Share on other sites
Handy Don 15,190 #74 Posted July 27, 2022 Just now, josephbruce11212@gmail.co said: Not the color I was hoping for.... Given that the tractor looks like it's been either left out or submerged (or both?), that is no shock at all. Lots of threads here if you search for "flushing diesel" that'll step you through getting after that. PLEASE be sure to dispose of the contaminated fluid responsibly. Also, you almost certainly will need a new boot for the shifter. Several of the vendor supporters of this site can fix you up 1 Share this post Link to post Share on other sites
Snoopy11 5,723 #75 Posted July 27, 2022 1 minute ago, josephbruce11212@gmail.co said: Looking for a seat I have a seat that @davem1111 gave me... it isn't in absolutely horrible shape... but it could use a seat cover... I could include the seat bracket as well. I can get some pictures of it if you are interested? Don 1 Share this post Link to post Share on other sites
