Chrishar 544 #1 Posted July 22, 2022 I took it back apart for the 100 time need help Share this post Link to post Share on other sites
peter lena 8,720 #2 Posted July 23, 2022 @Chrishar obviousely been after every detail , just an idea , are you using a lubricant that has " climbing abilities " ? , not joking on that , could you possibly have a dry bearing / gear area ? are you using anything with a significant , wear pattern on it ? do you pre lube every contact point at reassembly, like engine building lubricant ? hope you find it , pete 1 Share this post Link to post Share on other sites
peter lena 8,720 #3 Posted July 23, 2022 @Chrishar https://www.bing.com/images/search?q=climbing+gear+lubricant&id=18FEDB644F630CDF3F7CD0FDCE65F1C3769F8BFC&form=EQNAMI&first=1&disoverlay=1 , worth a look , pete 1 Share this post Link to post Share on other sites
