6wheeler 668 #1 Posted July 21, 2022 (edited) Look at this. 1988 Coachmen Leprechaun. Sitting on a Ford E-350 chassis. 7.5l (460) engine. C-6 auto. 12162 actual 1 owner miles. Never sat outside til now. It will be in the shed when not in use. Hadn't been started since 2016. Put a battery in her? She fired right up. Cleaned the carb on the Onan Emerald1 genset and also fired right up. The genset had 22 actual hrs. Of run time on it. I just did the 4th oil change it has ever had. It needed rear tires. Even though they looked new? 35 year old tires tend to crack. The po put new fronts on in 2016 before he parked it. I put app. 100 miles on it so far and it drives great. Check it out. Edited July 21, 2022 by 6wheeler More pics 4 10 1 Share this post Link to post Share on other sites
Sparky-(Admin) 22,152 #2 Posted July 21, 2022 Nice 34 year old time capsule ya got there! No roof leaks? Share this post Link to post Share on other sites
Dan.gerous 2,696 #3 Posted July 21, 2022 It looks in better condition than my 2002 model, good score! Share this post Link to post Share on other sites
6wheeler 668 #4 Posted July 21, 2022 17 minutes ago, Sparky said: Nice 34 year old time capsule ya got there! No roof leaks? 1 in the rear left. I cleaned the spot. Only to find out? The Po had siliconed it. But? Must have put the gray stuff on. I don't know what it is called. I am new to this world. But? The silicone was still un-cured. Apparently? They put the sealer on before allowing it to cure. The grey stuff was hard, but, water must have been seeping under it. I wiped the silicone off with a paper towel. Anyway. I am using Everbond tape. That is what my rv'ing brother said to use. I flooded the top. And? So far? No leaks. Hoping it works. 6 Share this post Link to post Share on other sites
Pullstart 64,608 #5 Posted July 21, 2022 Congrats! It’s not always great having an RV, but we probably wouldn’t be without one! Share this post Link to post Share on other sites
Beap52 1,198 #6 Posted July 22, 2022 Good looking unit. We had a 1979 Coachman motor home and had a lot of fun with it. Sold it, still miss it but the trailer we now have works out better for us. I suggest keep an eye on the overhead bunk window in the front. Our showed some stains along the bottom and I ended up on rebuilding the whole front upper bunk area. Wasn't especially difficult but still somewhat challenging. We also ended up taking all of the house windows out, resealing them as the sealer used is usually dried out. I'll bet your brother in law will suggest NO silicone. With a RV in that condition, others at the campground will likely make comments on how great looking yours is. 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #7 Posted July 22, 2022 14 minutes ago, Beap52 said: NO silicone There are very very few applications that IMHO silicone performs acceptably. There are always better products. 1 1 Share this post Link to post Share on other sites
ineedanother 1,418 #8 Posted July 22, 2022 Nice! Everbond tape is tough and will last a surprisingly long time. I use it on the nose pieces on our Haulmark trailers (that ALWAYS crack) and it does well. Enjoy (when diesel prices come down)! 2 Share this post Link to post Share on other sites
lynnmor 7,575 #9 Posted July 22, 2022 Never, never use silicone caulk on an RV. Future repairs or caulking would be difficult. Share this post Link to post Share on other sites
Jeff-C175 7,203 #10 Posted July 22, 2022 3 minutes ago, lynnmor said: Never, never use silicone caulk on an RV. Future repairs or caulking would be difficult. So true. Once a surface is contaminated with silicone there is nothing that will remove it, making it impossible to get any product to adhere properly. In fact, I've found that new silicone won't adhere well to old siliconed surfaces. I really loathe silicone caulk. 2 Share this post Link to post Share on other sites
Tractorhead 9,093 #11 Posted July 22, 2022 Just a tip Unscrew and remove the roof mounted things like windows and vents remove all silicone with a silicon remover use butyl based sealant to reinsert the roofparts and you are good for the next 5 years. check each 5 years all sealants if the dryed out and refresh them if needed. 2 Share this post Link to post Share on other sites
Dan.gerous 2,696 #12 Posted July 22, 2022 6 hours ago, Jeff-C175 said: There are very very few applications that IMHO silicone performs acceptably. There are always better products. So true, its amazing it still has so much traction in the market place. 2 Share this post Link to post Share on other sites
peter lena 9,092 #13 Posted July 22, 2022 @6wheeler take advantage of what works , and enhance , verify those areas , would also go after the chassis with a penetrating oil soak down , to stop rust and save metal . often totally neglected , my son lives in northern vt , and yearly goes over his stuff , for oil soak down and look for upcoming service , basically has it down to tires , brakes , related . regularly does oil in door and chassis seams , zero rust . pete 1 Share this post Link to post Share on other sites
peter lena 9,092 #14 Posted July 22, 2022 @Snoopy11 seams like every time I pull in next to a late model pick up , ford / dodge / chevy , the rot / rust is already at work , those fender well seams , fender well lips / seams , solid rust leaf springs , tail gate rot , paint bubbles , ford under cab bolt rot seam ? , don,t know about you , but , personally would put a stop to it . a creeping penetrating oil , like for open gears and cable spray , would stop the start of that . finish with a 680 wt open gear spray , mine has never come off , new trucks are 60-70 k $ + , just talkin , keep it greasy , pete 1 Share this post Link to post Share on other sites
Snoopy11 5,717 #15 Posted July 22, 2022 8 minutes ago, peter lena said: @Snoopy11 seams like every time I pull in next to a late model pick up , ford / dodge / chevy , the rot / rust is already at work , those fender well seams , fender well lips / seams , solid rust leaf springs , tail gate rot , paint bubbles , ford under cab bolt rot seam ? , don,t know about you , but , personally would put a stop to it . a creeping penetrating oil , like for open gears and cable spray , would stop the start of that . finish with a 680 wt open gear spray , mine has never come off , new trucks are 60-70 k $ + , just talkin , keep it greasy , pete Yes sir. My green Ford Ranger has 270,000 miles on it... NOT A SPECK of rust on the frame because the previous owner sprayed the undercarriage. The undercarriage of the green and blue Rangers here on the funny farm are completely free from rust. A little precaution and care keeps rust away. Don 1 Share this post Link to post Share on other sites
