peter lena
getting video from you tube to red square
peter lena
@Pullstart  , did all the steps asked for on you tube to get to red square , cant make the connection , ideas , ?  thanks pete
Jeff-C175
I usually just copy and paste the URL and it goes...
That's what I did here...
Pullstart
Let’s break it down @peter lena… did you get the video on YouTube already?  Is it posting to RedSquare you’re hung up on?
peter lena
@Pullstart  yes thats the hang up , the video is on you tube , connection to R/S is not there , thanks pete
squonk
Pullstart
What is the title of the video and what is your YouTube name?
peter lena
@Pullstart   plow quadrant detailing  is what its called , terry lena is the name . pete
Pullstart
I’m not finding it on YT.  Is it marked public?
cafoose
@peter lena make sure you're signed into YouTube, click on "Your videos" on the left side.
In channel content page, click "unlisted" under "visibility" heading and choose "public". Now you should be able to share on Red Square :handgestures-thumbupright:
Edited by cafoose
Jeff-C175
@peter lena
Yeah, I can't find it either Pete...
peter lena
  • Excellent 5
peter lena
@Jeff-C175  been a real PIA  , thank you @Pullstart  and @cafoose for the effort , this just popped up , hardly seams worth the effort , should have been easy . plow was packed with rust and crud , barely moved , let alone swing . detailing the squeeze lever pull wires , and adding  longer bolts to the lever swing points with elastic lock nuts / washers / lube , lets you screw in a sweet tension spot that easily directs the quadrant , slide slug , under spring push . cnc red aerosol grease , and lucas  xtra hd grease . build it in an elevated spot just like its hanging under the horse .  thats exactly how it will work when mounted , verify it first . thanks again , pete
Jeff-C175
I've been called worse!
  • Haha 4
peter lena
@Jeff-C175  sorry about that , not intended for you, was talking . (  but not referring ) to overall video experience , pete
Jeff-C175
I know, no problem!  Knew what you meant but couldn't resist funnin with ya!
  • Haha 1
