peter lena 9,051 #1 Posted July 16, 2022 @Pullstart , did all the steps asked for on you tube to get to red square , cant make the connection , ideas , ? thanks pete Share this post Link to post Share on other sites
Jeff-C175 7,203 #2 Posted July 16, 2022 I usually just copy and paste the URL and it goes... That's what I did here... 1 Share this post Link to post Share on other sites
Pullstart 64,344 #3 Posted July 16, 2022 Let’s break it down @peter lena… did you get the video on YouTube already? Is it posting to RedSquare you’re hung up on? Share this post Link to post Share on other sites
peter lena 9,051 #4 Posted July 16, 2022 @Pullstart yes thats the hang up , the video is on you tube , connection to R/S is not there , thanks pete Share this post Link to post Share on other sites
Pullstart 64,344 #6 Posted July 16, 2022 28 minutes ago, peter lena said: @Pullstart yes thats the hang up , the video is on you tube , connection to R/S is not there , thanks pete What is the title of the video and what is your YouTube name? Share this post Link to post Share on other sites
peter lena 9,051 #7 Posted July 16, 2022 @Pullstart plow quadrant detailing is what its called , terry lena is the name . pete Share this post Link to post Share on other sites
Pullstart 64,344 #8 Posted July 16, 2022 16 minutes ago, peter lena said: @Pullstart plow quadrant detailing is what its called , terry lena is the name . pete I’m not finding it on YT. Is it marked public? Share this post Link to post Share on other sites
cafoose 3,383 #9 Posted July 16, 2022 (edited) @peter lena make sure you're signed into YouTube, click on "Your videos" on the left side. In channel content page, click "unlisted" under "visibility" heading and choose "public". Now you should be able to share on Red Square Edited July 16, 2022 by cafoose Share this post Link to post Share on other sites
Jeff-C175 7,203 #10 Posted July 16, 2022 @peter lena Yeah, I can't find it either Pete... 1 Share this post Link to post Share on other sites
peter lena 9,051 #12 Posted July 17, 2022 @Jeff-C175 been a real PIA , thank you @Pullstart and @cafoose for the effort , this just popped up , hardly seams worth the effort , should have been easy . plow was packed with rust and crud , barely moved , let alone swing . detailing the squeeze lever pull wires , and adding longer bolts to the lever swing points with elastic lock nuts / washers / lube , lets you screw in a sweet tension spot that easily directs the quadrant , slide slug , under spring push . cnc red aerosol grease , and lucas xtra hd grease . build it in an elevated spot just like its hanging under the horse . thats exactly how it will work when mounted , verify it first . thanks again , pete 2 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #13 Posted July 17, 2022 44 minutes ago, peter lena said: @Jeff-C175 been a real PIA I've been called worse! 4 Share this post Link to post Share on other sites
peter lena 9,051 #14 Posted July 17, 2022 @Jeff-C175 sorry about that , not intended for you, was talking . ( but not referring ) to overall video experience , pete 1 Share this post Link to post Share on other sites
Jeff-C175 7,203 #15 Posted July 17, 2022 2 hours ago, peter lena said: @Jeff-C175 sorry about that , not intended for you, was talking . ( but not referring ) to overall video experience , pete I know, no problem! Knew what you meant but couldn't resist funnin with ya! 1 1 Share this post Link to post Share on other sites
