gino 0 #1 Posted July 8, 2009 Hi, I am new to this site. I have Lawn Ranger L 107 , 1967 with tecumseh h60-755446k SER 0035c .I need help with Carb Linkages.I have just rebuilt this engine, but it didn't come with correct linkages, and spring. Is there anybody that can provide me with some pictures that will show me what the linkeges and spring are correctly supposed to look like. I have searched many forums and manual but I couldnt found anything that looks like mine.The only thing that looks like my engine goes by name Snow King. I appreciate anyone that can help me in this matter. There are some pictures of my engine. Attached Image Share this post Link to post Share on other sites
gino 0 #2 Posted July 8, 2009 more pictures of engine Attached Image Share this post Link to post Share on other sites
Duff 206 #3 Posted July 8, 2009 Hi, Gino! I don't know anything about Teccy engines, but I'm sure someone will come along who does and should be able to help you out. So I just wanted to say, ! Glad you found us! Duff :thumbs2: Share this post Link to post Share on other sites
sorekiwi 761 #4 Posted July 10, 2009 None of my Tecumsehs have looked like that one! Here's a pic of an H55 which I think is the same linkage arangement as the H60: Share this post Link to post Share on other sites
Michael Bullington 5 #5 Posted July 10, 2009 Hey Mike, The set up is a throttle setup is a little different on his model.....there is a bracket that mounts to the head bolts that the throttle is mounted to....then a small spring goes from that bracket to the carb...they changed inbetween model year 63 and 64..Ive got a picture somewhere i just got to find it. Share this post Link to post Share on other sites
gino 0 #6 Posted July 10, 2009 thanks guys for all of your replies I am still looking,can't find anything. :thumbs2: Share this post Link to post Share on other sites
here 4 the horses 1 #7 Posted July 10, 2009 i have 2 h60's ill get a pic tomarrow for you Share this post Link to post Share on other sites
Coadster32 793 #8 Posted July 10, 2009 I have HH60 techhy. I could post a pic of that setup for you. BTW- what's the differect between a HH60 and H60. (besides an H) :thumbs2: Share this post Link to post Share on other sites
Michael Bullington 5 #9 Posted July 10, 2009 HH has the steel sleeve with Cast Iron block Michael Share this post Link to post Share on other sites
evanloock 226 #10 Posted July 10, 2009 HH=heavy duty horizontal which is a cast iron block engine H=horizontal which is an aluminum block engine Share this post Link to post Share on other sites
Coadster32 793 #11 Posted July 10, 2009 Would it be safe to assume all of the the alum. blocks to be sleeved? Above is off of a HH60 setup. Looks different from yours. Below are off a H40 setup. Similar to yours. This motor isn't mounted, but I hope the pics help. Good Luck. Share this post Link to post Share on other sites
oldandred 15 #12 Posted July 10, 2009 chris the alum, blocks were not sleeved and I dont think they can be sleeved theres not enough there to bore Share this post Link to post Share on other sites
pfrederi 18,279 #13 Posted July 11, 2009 oldandred said: chris the alum, blocks were not sleeved and I dont think they can be sleeved theres not enough there to bore I looked at the engine manual for my L-107. Tecumseh Model H60-75118F It says " CYLINDER- Aluminum Alloy die casting with INTEGRALLY CAST ALLOY IRON SLEEVE - 75117F & 75118F" Caps were in manual Share this post Link to post Share on other sites
gino 0 #14 Posted July 29, 2009 thanks guys so much for all replies and pics i did finished that engine hier are some pics thanks Attached Image Share this post Link to post Share on other sites
gino 0 #15 Posted July 29, 2009 pic#2 crappy camera Attached Image Share this post Link to post Share on other sites
gino 0 #17 Posted July 29, 2009 pic#3 Attached Image Share this post Link to post Share on other sites
gino 0 #18 Posted July 29, 2009 pic#4 Attached Image Share this post Link to post Share on other sites
gino 0 #19 Posted July 29, 2009 pic#5 Attached Image Share this post Link to post Share on other sites
gino 0 #20 Posted July 29, 2009 here is a tractor its gonna be next over haul Attached Image Share this post Link to post Share on other sites
Coadster32 793 #21 Posted July 29, 2009 Good job! :thumbs2: Share this post Link to post Share on other sites
TT-(Moderator) 1,147 #22 Posted July 29, 2009 That looks really spiffy, gino. Just remember to get a brace on that exhaust pipe or you could end up with a stripped or broken port. :thumbs: Share this post Link to post Share on other sites
stevasaurus 23,040 #24 Posted July 30, 2009 gino...that looks way too nice to get dirty. :thumbs2: Share this post Link to post Share on other sites
