Similar Content
By Ifixoldjunk
I just bought a deck for my 310-8, it’s a 42inch rear discharge, it came with a complete parts tractor, but I need new belts for it. Does anyone know what size belts I need?
By Ifixoldjunk
So I’ve picked up a 310-8 recently and I’d like to start finding attachments for it.
the route I’ll probably go is picking up a parts tractor to rob attachments off of. I’d like to know what tractors have interchangeable attachments with the 310. Would a blackhood or a b series have similar attachments?
I’ve always been a bolens guy, so this whole wheel horse thing is new to me. Thanks for any help.
By CB1993
Hello. I just purchased a 1277 today and was wondering if there was any info on the mower deck. Is there a manual for this deck? What kind of belt is used? I have attached some pics. Thanks for any input.
By Rob R
Hi guys need you help have a 42" side Discharge Deck (Triple Blade) mower deck, mounted on a C-81, that is in bad need of an outside Spindle (Mandrel) the pulley on top is # 5877. The bottom bearing is toast. so I poise the following questions. Note pics attached.
1. Does any on have one of these for less then a Kings ransome?
2. Is it possible to disassemble and install an new bearing from like NAPA?
3. All three spindles have NO Zerk grease fittings can I drill and add some...... if yes where on the housing is the best place to do this.
Thanks feel free to add any other options......
By Bob22
Is pulley bar on tension spring free to move or anchored on end with locknut.
