953 nut 57,885 #26 Posted July 11, 2022 4 hours ago, The Freightliner Guy said: the pulley on the engine is about 2 inches in circumference I think you meant to say diameter of 2", 2" circumference would be about 5/8" diameter. 16 minutes ago, The Freightliner Guy said: I I just want it to be able to drive around at 9mph Nine MPH on a narrow garden tractor with very little braking force and steering that is rather sloppy at best not to mention a quick steering ratio is probably not a good idea. 3 minutes ago, The Freightliner Guy said: For a pulley remover You can barrow or rent a puller from most auto parts stores. 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #27 Posted July 11, 2022 The tractor has no brakes and I broke the steering pin 3 days ago 1 Share this post Link to post Share on other sites
Pullstart 64,523 #28 Posted July 11, 2022 Keep in mind that the belt guard on normal tractors is the clutch and the lever is just the tensioner. Once you get it running, the belt MUST be 100% stopped before shifting. Never try to jam gears while the belt is moving 1 1 Share this post Link to post Share on other sites
wallfish 17,487 #29 Posted July 11, 2022 Personally, I would just cut it off. Probably faster to do that too. Just don't cut into the shaft. Again, just try a belt first and go from there. https://www.amazon.com/Maxpower-347472-Premium-Reinforced-Kevlar/dp/B0126MPE00/ref=asc_df_B0126MPE00?tag=bingshoppinga-20&linkCode=df0&hvadid=80608001419701&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4584207579366491&psc=1 How about a pic of the steering pin you broke? I'm not sure what pin you're referring to 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #30 Posted July 11, 2022 I don’t got a pic sorry but it’s a pin that goes in the steering shaft all the way at the front so the steering wheel turns fine cuz there’s no pin in it so it can turn the tires 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #31 Posted July 11, 2022 Do you think that Kevlar belt would fit 1 Share this post Link to post Share on other sites
953 nut 57,885 #32 Posted July 11, 2022 10 minutes ago, The Freightliner Guy said: I don’t got a pic sorry but it’s a pin that goes in the steering shaft all the way at the front so the steering wheel turns fine cuz there’s no pin in it so it can turn the tires If this is the pin you are missing you can make one by welding/brazing a washer on the end of some round rod of the correct size. 2 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #33 Posted July 11, 2022 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #34 Posted July 11, 2022 Look down at the steering colom that’s where the snapped pin was 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #35 Posted July 11, 2022 Where that box thing is right about there 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #36 Posted July 11, 2022 And when the snapped pin came out it had a bend in the middle so I don’t think the holes can be aligned cuz I tried shoving a thic nail in ther hole and it wouldn’t fit 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #37 Posted July 12, 2022 I think when the pin snapped it left a small piece in it 1 Share this post Link to post Share on other sites
Pullstart 64,523 #38 Posted July 12, 2022 On 7/11/2022 at 1:11 PM, Pullstart said: You can learn quite a bit from the manual. Here is the illustrated parts list from the link I posted. Maybe it would help us determine what pin we’re talking about? 2 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #39 Posted July 12, 2022 I’ve seen this before 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #40 Posted July 12, 2022 On the diagram part 37 is the part that snapped on my rjs steering 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #41 Posted July 12, 2022 The part that looks like a pin at the bottom of the diagram is the part I snapped 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #42 Posted July 12, 2022 Which ever one that is at the bottom that has a 7 in the number that’s the pin the snapped 1 Share this post Link to post Share on other sites
wallfish 17,487 #43 Posted July 12, 2022 Typical roll pin (tension Pin). You can get a whole kit for $5 https://www.harborfreight.com/120-piece-roll-pin-storehouse-67591.html?utm_source=bing&utm_medium=cpc&utm_campaign=425671841&campaignid=425671841&utm_content=1165483352453450&adsetid=1165483352453450&product=67591&store=&msclkid=45913633c4581508f7a054fe00d72812 Think they're 1/4" roll pins. Sometimes you can just knock out the old pieces with the new pin as you tap it in. 2 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #44 Posted July 12, 2022 The thing is that the holes are not aligned which is probably why the pin had a bend in the middle 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #45 Posted July 12, 2022 And there’s not really room for a hammer 1 Share this post Link to post Share on other sites
wallfish 17,487 #46 Posted July 12, 2022 Then someone redrilled it. The holes should all line up to hold the block to the steering shaft. It needs to go straight through the whole thing. 1 minute ago, The Freightliner Guy said: And there’s not really room for a hammer Disconnect the steering link and turn it so you can get to it from the bottom. The hole will face down 1 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #47 Posted July 12, 2022 The thing is that I don’t know how to disconnect it cuz it’s like welded 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #48 Posted July 12, 2022 Here I’m having my grandma take a pic for me cuz it’s in their back yard 1 Share this post Link to post Share on other sites
wallfish 17,487 #49 Posted July 12, 2022 44 minutes ago, The Freightliner Guy said: The thing is that I don’t know how to disconnect it cuz it’s like welded Mother nature brown weld. It's rusted 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,335 #50 Posted July 12, 2022 I’m kinda overwhelmed with my rj the fuel tank is super nasty the air filter is shot I need to clean the carb the tank fix steering and I need to buy new front rims cuz they have holes but the air fill up cap do any of y’all know how I could get the same sized rims it had on it currently 1 Share this post Link to post Share on other sites
