peter lena 8,625 #1 Posted July 11, 2022 just some morning shots , before a check over , this is my frankenhorse for all my experiments , for problem removal / upgrades , any modifications were thoroughly tried and verified as a solid fix to any related problem, lots of hours , then apply it to my other 2 horses . if I tell you a change works , it reliably does . typically , just altered the way anything was set up , or regularly failed . really don't even think about the hours, because i,m always snoopin around . jump on anything as soon as it shoes it self . greasy pete 3 15 Share this post Link to post Share on other sites
Pullstart 62,855 #2 Posted July 11, 2022 Original paint? Looks beautiful! 1 Share this post Link to post Share on other sites
peter lena 8,625 #4 Posted July 11, 2022 @Pullstart original paint , over the years , I have rubbed it down with penetrating oil to feed the paint , its really a very simple /easy thing to do , and it works without effort . originally did that on used stuff I got , don't even think about it , clean cloth , aerosol lubricant on clean paint , pow ! that lubricant fed paint is deep and solid in shine , weeks later , just some spray wax , try it , you'll like it , pete 1 2 1 Share this post Link to post Share on other sites
Retired Wrencher 5,454 #5 Posted July 12, 2022 Nice ride Pete. I like you just use Marvel on everything. Easy color. 1 Share this post Link to post Share on other sites
peter lena 8,625 #6 Posted July 12, 2022 @RETIREDW RENCHER .see it ? hiding in plane site , same pictures , #5 / 6 , notice the silver ,vertical fuel check valve just under the carb ? https://www.amazon.com/EVIL-ENERGY-Return-Petrol-Aluminium/dp/B07ZB42CGT/ref=sr_1_1_sspa?. have them on each horse , lots of hours , no problems , near instant starts , made up the refit with clear vinyl fuel line , dark green squeeze clamps , exact size to size fit, just measured the length needed from carb intake to pump area . like i said , this horse has been a test bed , for problem / issue , change out , you have to get fed up with an ongoing issue , to make the change , have a good day , pete 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #7 Posted July 12, 2022 Tractor looks great much better condition than my mystery rj Share this post Link to post Share on other sites
peter lena 8,625 #8 Posted July 12, 2022 @The Freightliner Guy , always kept in a shed , just try to give it a regular rubdown , weather its , lubrication or a 6" palm buffer with a cleaner wax , its been a very solid unit , don't really need a show horse. regularly rotate my 3 , for grass and snow . expecting some heavy rain / wind tonight , WE COULD USE IT , PETE 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #9 Posted July 12, 2022 Yeah I just want it in operating condition and not dodgy like how it probably was before parked in 2008 1 Share this post Link to post Share on other sites
The Freightliner Guy 1,327 #10 Posted July 12, 2022 This rj has been rained and snowed on for 14 years in a backyard in Ogden utah Share this post Link to post Share on other sites
Retired Wrencher 5,454 #11 Posted July 13, 2022 (edited) 21 hours ago, peter lena said: @RETIREDW RENCHER .see it ? hiding in plane site , same pictures , #5 / 6 , notice the silver ,vertical fuel check valve just under the carb ? https://www.amazon.com/EVIL-ENERGY-Return-Petrol-Aluminium/dp/B07ZB42CGT/ref=sr_1_1_sspa?. have them on each horse , lots of hours , no problems , near instant starts , made up the refit with clear vinyl fuel line , dark green squeeze clamps , exact size to size fit, just measured the length needed from carb intake to pump area . like i said , this horse has been a test bed , for problem / issue , change out , you have to get fed up with an ongoing issue , to make the change , have a good day , pete You have it working with those changes Pete. But I only have old style gravity feed engines. Edited July 13, 2022 by Retierd Wrencher 1 Share this post Link to post Share on other sites
