joskuk
New to me 1979(?) C-81
Pullstart
Gongrats and :text-welcomeconfetti: back!
peter lena
@joskuk  that paint looks like it could be recovered to me , save the patina with a penetrating oil rub down , aerosol spray it all down every painted surface . let it sit a day preferably in the sun , that hot metal will suck in that oil thru the paint , and save it . next day rub it down till dry , no sanding . now spray it down again , same thing , next day rub it down till dry and look at its lubricated paint looks , you have just saved patina . you could could finish it with linseed oil. that would look sharp , and it would shed water like a fresh wax job , but last much longer . pete
Blasterdad
She's a '79 & in GREAT shape!
The C-81's are my favorites in the stable, ( I have 4 now ) & FWIW she will run that 42" deck, run her at full throttle when mowing & towing so she gets the oil & cooling she needs.
The K181 is a great engine & good on gas too!
Nice find. :)
joskuk
Interesting idea! I would like to give this a try...do you just use any penetrating oil like PB Blaster? And would the linseed oil need the same day to soak in? There are a couple spots where the paint is gone but I think this will keep the look and prevent any additional rust from forming.
Nice find. :)
That's what it looked like to me, thanks for confirming! I guess I'll have to try mowing with it once I get everything working properly. Being a little lighter on gas sounds nice right now! The 416 can definitely drink some.
peter lena
@joskuk have not used pb blaster , but its probably in the same lubrication feeding zone as what I do . actually did that as an experiment years ago , neglected paint starved for some kind of attention / upkeep . just sprayed an area , and forgot about it , busy with other stuff, next time I  saw that area , there was water shedding patina ! so I  just tried a little recovery as my experiment went along . you will not loose anything by doing this , easy , pete
Blasterdad
I cut in around the house, trees, bushes, & garage with the C-81 with a 36" RD deck first, then finish with the C-120 with a 48" SD deck.
The C-81 sips fuel comparatively. :)
