Countdown To Christmas!
Similar Content
By Bill D
Can I change the hoses on my GT1800 without draining the transmission? Thanks.
By Bill D
I have a GT1800 that I have swapped an M14 into. The original drive belt is too long for the Kohler. I tried a 7473 belt and that was too long. I'm guessing I need an 81" belt. Does anyone know for sure? I'm thinking it should be the same length as a 314H? I'm trying to avoid multiple trips to TSC with the price of gas. Yes, I do have the correct hydro pulley on the Kohler. Thanks.
By Bill D
I wanted a pedal control for my recently acquired GT1800. This is what I came up with. It still needs some finishing and I may rework the foot pedal. It's basically bolt on other than drilling a 7/8" hole in the belt cover. I'm also considering building an automatic neutral return if I can find the right torsion spring. I would appreciate any input and advice.
By Bill D
Does anyone have a part number or source for the plastic washer that goes between the hub and transmission housing on the Eaton 1100's. Can't seem to find a part number in the diagrams. Thanks. Bill
By GEnd
Hi members,
looking at picking up my first red tractor this weekend, but the owner has discovered and disclosed what appears to be a leak behind the "brake drum" which is just behind the PTO clutch. Photo shows oil pooling at the bottom of the drum. Looks like seal 253-44 could be the culprit. I'm guessing this is a relatively easy fix, but if you have done this or have expertise/advice to share, I'd love to hear your thoughts before I make a deal. Thanks!
