Allen E. 1 #1 Posted July 6, 2022 Anyone know the size of the upper belt on a Wheelhorse 208-3 mowing deck? Pretty sure it is a 1/2" V-belt at least 40". Also the foam air cleaner on the 8hp B&S engine replacement part # Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #2 Posted July 6, 2022 What size of deck? 32" side discharge two blades 36" rear discharge three blades 37" side discharge two blades Decks are sized by their width of cut - not the width of the deck Air filter https://www.partstree.com/models/191707-2153-01-briggs-stratton-vertical-engine/carburetor-fuel-tank-assy-2/ Item 535 is foam Share this post Link to post Share on other sites
Allen E. 1 #3 Posted July 6, 2022 32" Deck. Thanks for the info on the air cleaner!! Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,243 #4 Posted July 6, 2022 Click on the picture in each link. May not be the exact model deck you have but the belts will be the same. Share this post Link to post Share on other sites
