IthacaJeff
Kohler K341 knocking under load
IthacaJeff
Hi all:
I've got a newly acquired and beat up 416-8 with a Kohler K341 16hp engine.
After replacing the cylinder head and testing it out with an hour of easy mowing,
I took the tractor to a piece of land to do a bit of brush hogging. For about 15-20
minutes it worked great. . . the tall grass was no match for it.
Then it starting bogging down some, so I went to a lower gear. . . but after a bit
it started bogging down under load some more, and then started a nasty knock
or rattle. I powered down and took the tractor home. After getting it home I started
it up again and mowed for about 20 minutes with no knock or problems.
The tractor is missing the engine sheet metal that covers the head. . .I'm guessing
this helps run air over the head cooling fins. Could this be part of the problem?
Any suggestions?
Thanks,
Jeff in Ithaca
WheelHorse_of_course
I would tend to agree with your hypothesis. Air cooled engines are carefully designed to get air to all the right spots.
Best of luck
perry
get the sheet metal on there. but i would bet you need to set the timeing. no let go to long. timing is important.
