Jennifer
Daughter’s first pulling tractor!
ebinmaine
The tractor appears to be a 1973 10 HP 8 speed.
I don't believe these were originally built with Limited Slip Differentials.... ((??))
@stevasaurus
What did you use for a transmission?
Any modifications?
Locked differential?
Flipped pinions?
Welded gears? (I REALLY hope not)
If it's an "open diff" transmission it's perfectly normal for each wheel to spin independent of one another.
You could get the whole rear off the ground and listen for crunchy crackly noises.
Remove both wheels. Carefully check the hubs.
See if the keys, hub or axle keyways or even a set screw is damaged or broken.
If nothing is found on the outside, the only accurate way to find the problem is to pop open the transmission.
Easy stuff with basic hand tools.
Take more pics during disassembly...
Keep us posted and keep asking questions!
Pullstart
I hear the crunch at :22 and am surprised that IF that was the damage being done, that it kept going.  As EB mentioned, try inspecting all keys outside before opening it up.  There’s the input shaft keyway, hub keys, etc.  My concern is how you said nothing in low side will happen.  You have zero low range?  That would almost have to indicate internal damage…
  • Sad 1
stevasaurus
If that horse is a 1973 10-8 with the factory transmission, it has the #5086.  A quick check is to find out if it has 1" axles.  If 1" axles, it is a 4 pinion differential.  Like was said above, check all 3 keyways.  If the keys are good, I suspect the high/low range has a gear with teeth missing or broken.  Anyway, it is fixable with a little love.  This is the #5091, only difference 1 1/8" axles and 8 pinion differential.  Let us know Jennifer.  :occasion-xmas:
Jennifer
@stevasaurus today’s the fourth so we’re not gonna spend a lot of time on the tractor we’re going to have some family quality time celebrating the freedoms that we take for granted every day I remember those that sacrificed the ultimate for our freedom but I did take a quick measurement of the axle!
@ebinmaine  we truly know nothing about this tractor other than what I was told and the one that sold it to me was able to give us the name and some pictures of the creator pulling it…. With that said until we get a hold of this person and talk to him about what all modifications were done we are in the dark here…we did nothing but bought it! 🤪. It just seemed like the thing to do!  Lol..
We appreciate all the advice from all the Wheel Horse gurus hopefully we can get this tractor up and going again for the pulls that are coming up!  Thanks again and happy Fourth of July! Happy Independence Day everyone!  God bless the USA!
Pullstart
@Jennifer do you have another 8 speed to swap in for the time being?
Jennifer
Husband picked one up at the big show without checking it out…. Something is wrong with it…. The low and high lever won’t move!  😬
  • Sad 2
Wild Bill in VA
Jennifer,
 For a old Wheel Horse trick fill the transmission up with kerosine down the shifter hole and let it a few days. Then try rocking the input shaft and axles back and forth but do not force any of the shafts. Then try moving the Hi/Low shifter while tapping lightly with a hammer the shifter at the base. Push come to shove ....... heat around the base of the Hi/Low shifter with a propane torch then wrap  ice cubes around the base of the shifter. The ice will shrink the steel rod in the cast housing and let the shifter move. The clearance is very tight, and rust will build up locking the shaft.
Wild Bill in Richmond VA
Jennifer
Husband is getting frustrated!!!!  Can’t get the hubs off ether transmission!  Also wants to know if someone could identify each transmission.
ebinmaine
Exactly what are you using as a puller?
Jennifer
Also anyone have this rod that connects to the brake band…?   Nut about off and then broke the shaft off instead..
  • Sad 1
Jennifer
His three arm pulley puller!  Then tried a block of 2x4 to hit close to the shaft…🤷🏻‍♀️
ebinmaine
WHOA. WHOA. WHOA.
Both of those are VERY bad for a Wheelhorse transmission.
You NEED a good puller to be successful removing Wheelhorse hubs.
Go through the thread I've pasted here:
There are some great puller ideas.
It's also extremely important to remember the rust took 4 or 5 decades to form. It won't disappear in 10 minutes.
I've had hubs under constant pressure take 2 WEEKS to pop off.
Heat.
GOOD penetrating oil. (NOT PB or WD regular formula).
Patience.
Time.
More patience....
Jennifer
Update @Pullstart he was able to get low side the shifter just wasn’t going over or in all the way!  Transmission is out of tractor now and I guess hubs are going to slow the progress to the inside issue!
Jennifer
Problem found!!!  On the way back to repair!!!  Couldn’t get hubs off shaft ended up coming out…. That was a plus really!  Was able to put in a press!
  • Sad 2
Jennifer
Rebuilding has begun lol
Blasterdad
Wow! Those spider gears were toast! Your new diff looks pretty good. :thumbs:
ebinmaine
This is where the 8 speed has the advantage over a 4.
Twice as many pinion gears.
Hopefully the new one will be better.
Snoopy11
Yessir... I heard the same thing at the same time...
YYYYYOOOOOUUUUUUCCCCHHHHH!!! :jaw:
Don
  • Haha 1
Jennifer
Same diff…. Just changed the axles and guts…. 🤞🏻
Pullstart
Oh boy that could have been much worse!  Glad you found it!
Jennifer
Well…. Supplies are bought and heading home… Husband is putting anti-Seize on the hubs!
  • Excellent 2
Jennifer
Well it was a pretty good day for the daughter!  Not so much for the husband…. Trying to get videos from Grandma and friends!  Daughter got 2nd place!  Pulling 234.94. Husband didn’t place…. Apparently he was leaning back and the seat came unlatched… causing him to fall back and off the pedal…😬.  He was pretty happy with the transmission holding up!  Guess he had little faith in his repair job!  🤷🏻‍♀️ They had a great time and that’s what matters!  There moving towards more pulling at some distance just to get as many in as they can!  Thinking of traveling to Kansas in a few weeks…. 🤦‍♀️
Edited by Jennifer
  • Excellent 2
Jennifer
Well a long day!  The kids where are it again!  Yes even the big kid I married!  😂…. We drove around 2 1/2 hours for the kids to pull again today!  It was super hot out but all had a blast even the daughter that didn’t place today but was a good sport after threatening her dad a little… lol.  We are in need of more weights lol… so that’s on the list now!  Her dad out weighed her!
Edited by Jennifer
Jennifer
Also something to be done with the seat!  It keeps popping up!  😬😬😬😬
