rmaynard 15,927 #26 Posted July 3, 2022 1 hour ago, EB-80/8inPA said: Wasn’t there a thread on here not too long ago in which someone claimed, credibly, that the Wally World Super Tech was the exact same stuff as Mobil 1, if memory serves, both coming from the same refinery? It's probably made by Warren Oil. Their full synthetic actually tested better than Mobil 1. So I say, what difference does it make? It's not a high speed transmission, and most of us have a little if not a lot of water in it anyway. 2 Share this post Link to post Share on other sites
ebinmaine 70,779 #27 Posted July 4, 2022 11 minutes ago, rmaynard said: what difference does it make We've all drained coffee colored nastiness from a manual transmission at one point. These rigs are TOUGH. I've wondered more than once if these transmissions would be just as happy with canned spray cheese as gear oil. I can find multiple sources on the interwebs that state the GL5 "may harm" yellow metals in the transmission. What I can't find is any justification for or against what it would do (if anything) to a Horse transmission. 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,794 #28 Posted July 4, 2022 11 minutes ago, rmaynard said: and most of us have a little if not a lot of water in it anyway. One of these fine days I’ll have to drill out the drain plug on the No Name 8/4 and see where on that spectrum it is. I feel pretty squeamish about doing that, tbh. That’s like the first step to triggering the need for a complete rebuild. 2 Share this post Link to post Share on other sites
ebinmaine 70,779 #29 Posted July 4, 2022 12 minutes ago, EB-80/8inPA said: have to drill out the drain plug Stripped out head? 1 Share this post Link to post Share on other sites
Rob J. 1,942 #30 Posted July 4, 2022 37 minutes ago, ebinmaine said: Stripped out head? Yikes 1 Share this post Link to post Share on other sites
Rob J. 1,942 #31 Posted July 4, 2022 I’m thinking 80/90 GTG in a manual. 1 Share this post Link to post Share on other sites
Rob J. 1,942 #32 Posted July 4, 2022 (edited) 1 minute ago, Rob J. said: I’m thinking 80/90 GTG in a manual. My thinking also is the thicker it is the smoother it will be to a point. Edited July 4, 2022 by Rob J. 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,794 #33 Posted July 4, 2022 (edited) 41 minutes ago, ebinmaine said: Stripped out head? Aye. Frozen in situ. Rusted in place. Completely uncooperative. I tried all the suggestions. It’s hopelessly seized. Edited July 4, 2022 by EB-80/8inPA 2 Share this post Link to post Share on other sites
Rob J. 1,942 #34 Posted July 4, 2022 Just now, Rob J. said: My thinking also is the thicker it is the smoother it will be to a point. One caveat is is severe cold climates this not necessarily applies. I live in cold climate but my horses are stabled. 1 Share this post Link to post Share on other sites
WHX?? 50,752 #35 Posted July 4, 2022 4 hours ago, stevasaurus said: Even that Marine lower unit ......4 stroke outboards don't need it. Can someone school me on why. My outboard is about as vintage as my tractors. I would think there needs to be something in ther to lube bevel gears & bearings? 1 1 Share this post Link to post Share on other sites
EB-80/8inPA 1,794 #36 Posted July 4, 2022 18 minutes ago, WHX?? said: Can someone school me on why. My outboard is about as vintage as my tractors. I would think there needs to be something in ther to lube bevel gears & bearings? I don’t get it either. How is the LU’s operation or lubrication needs affected by the type of engine? 1 Share this post Link to post Share on other sites
WHX?? 50,752 #37 Posted July 4, 2022 Pressure lubes off the engine perhaps? What happens when the prop shaft seal leaks water in then? 1 Share this post Link to post Share on other sites
oliver2-44 10,370 #38 Posted July 4, 2022 2 hours ago, ebinmaine said: I can find multiple sources on the interwebs that state the GL5 "may harm" yellow metals in the transmission. What I can't find is any justification for or against what it would do (if anything) to a Horse transmission. As I recall from the lube classes it is the sulfur in the GL5 that will harm yellow metal. But the oil has to be HOT for that harm to occur. I don’t think these gear drive get hot enough for it to matter. 1 Share this post Link to post Share on other sites
pfrederi 18,334 #39 Posted July 4, 2022 Or run Straight 40w motor oil..WH specified it for a couple years. My 1967 Lawn Ranger my father bought in May 1967 has run on 40w for 55 years now. Used year round no issues.... 3 Share this post Link to post Share on other sites
stevasaurus 23,072 #40 Posted July 4, 2022 My 60 hp Mercury outboard (4 stroke) has no plugs for the lower unit like my 2 stroke outboards. Believe me, I looked and read the manual. It has an oil filter like a car and takes 3 qts of 25W-40. Of course the engine can't hold that much oil, so some of it circulates into the lower unit. It still is water cooled though. When you drain this puppy, you raise the engine all the way and tilt it on it's side. As far as the shaft seals, that is why you check the oil before use. I love this engine, so quiet and smooth starting and running. 2 Share this post Link to post Share on other sites
peter lena 9,091 #41 Posted July 4, 2022 @JoeM , think a lot of the issue's is a long overdue service / changing long over due oils . regularly check mine , always clean and clear . still drop it every other year , always a fresh shift boot , zero moisture entry . don't have any discoloration in the oil at all , just talking from my own experience , pete 1 Share this post Link to post Share on other sites
lynnmor 7,567 #42 Posted July 4, 2022 When machining brass or copper, the correct cutting oil should be used to prevent staining. This reaction takes place quickly and often the parts will become ugly overnight, ask me how I know. The same will happen inside a gear box and those parts will be exposed to the offending lubricant for years. Before jumping to conclusions about the suitability of certain oils one should research the use of a product that is different than what is specified. 1 2 Share this post Link to post Share on other sites
