Thegearhead0324
1257 Proud
ebinmaine
WOW!!
Fill THOSE tires with fluid and you'll have a bit of ballast!!
@Pullstart
ebinmaine
6 minutes ago, Thegearhead0324 said:
rims
Where'd the rims come from?
Pullstart
1 hour ago, ebinmaine said:
WOW!!
@Pullstart
weeeee doggy!
26x12-12 is a big piece of rubber for sure!
Edited by Pullstart
  • Haha 1
Thegearhead0324
I'm done for the day, but front tri ribs are on. I gotta touch up the rims after mounting all tires. But went well.
The wide rear rims I got online cheap, I'm not sure what they were off of, but they were rusty and yellow so I cleaned them and sprayed them. I first bought 8.5 wides but they were too narrow for the look I wanted so got these which are a couple inches wider. Was trying not to have sidewall bulge.
Its crazy what a difference tires make tho.
  • Like 4
Thegearhead0324
I very happy about the way it came out. I was so nervous about fitment and looks because I spent a lot of money on the tires, but glad I did. I feel like I'm part of the "big tire" club.
  • Excellent 4
Pullstart
That’ll fit right in this thread!
  • Like 4
Thegearhead0324
@Pullstart I'll definitely be posting a pic in there!
Thegearhead0324
Just took these of my battery setup.
  • Excellent 3
Thegearhead0324
Basically done with the rear of the 1257. It’s off jack stands. Got the inner and outer weights back in along with the hubcaps (jewelry.)
  • Excellent 4
Thegearhead0324
Tonight I started on the electric fuel pump set up. I mounted the pump under my fuel tank, ran the fuel lines with the filter and shut off valve. It looks ok for now. Just gotta run wires, relay and switch.
Thegearhead0324
I wired up the fuel pump with a switch and relay, I tell ya, runs good. I mean it always ran good, but fired right up better than before.
  • Excellent 2
Blasterdad
I go electric on all my :wh:'s when the manual pumps poop out, love the instant starts. :thumbs:
Thegearhead0324
Gotta do front wheel alignment and change oil, but first time she’s been out in 4 months.
  • Like 4
  • Excellent 2
Thegearhead0324
Couple more pics of the 1257.
  • Excellent 4
ri702bill
On 7/2/2022 at 6:06 AM, Thegearhead0324 said:
The sickle bar gives it character,
Gopher Patrol !!!!
Thegearhead0324
I changed the oil tonight and adjusted the tie rods. I may have to brace the rear pan with steel as I only have washers temporarily spacing it out half inch.
ebinmaine
You'll definitely want to get a spacer in there ASAP.
The flexing of the seat pan tool box around those washers will bend or break without having it resting on something larger like the top of the transmission.
Thegearhead0324
More pics of the 1257 w/ dump cart
  • Excellent 2
Thegearhead0324
Today I finished rebuilding the carburetor after noticing after my electric fuel pump install, it was leaking gas when it sat. So I cleaned/redid the carb with new needle and seat. Seems to be fine so far.
Thegearhead0324
So about my seat, where would I be able to find foam that would hold up and last? It’s original and good shape but is flat as a pancake.
953 nut
@BOB ELLISON can probably give you a good source for the faom.
Thegearhead0324
Thank you I will give him a try
BOB ELLISON
You can buy foam almost anywhere. But only get rubber foam. Here in Michigan I ordered from a company called Foam Express. I only got the (lux firm) it's made for seats and was as good or better then the original foam.
